587,002 active members*
2,781 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Drilling Holes in Aluminum
Page 1 of 2 12
Results 1 to 20 of 24
    Mar 2004
    847
    Hey all,
    I have my 10" Delta drill press and a decent set of HSS bits that go up to 1/4". However, now I need to drill some 1" and 2" size holes in some 1/4" 6061 plate.
    I bought a set of Harbor Freight el-cheapo-chinese forstner bits for a project (the Underwater ROV). They worked great for the plastic I was milling, but they have a million warning not to use them on metal.
    So, how does one go about making larger round holes in Alum. when they only have a drill press?
    Check Out My Build-Log: http://www.cnczone.com/forums/showthread.php?t=6452
    Mar 2005
    988
    In 1/4" you might be able to get away with buying whats called a "S&D" drill (Silver and Deming). For a 1", it should fit your chuck. You don't have a lot of power so just take it easy on it. I've drilled 1" + sized holes on a cheaper and smaller drill press and got by with it.
    The 2" hole is tough for trying to drill though. Instead, I use a hole saw. You're only going through 1/4 plate so it should be no problem. Just peck at it with some cutting fluid brushed on.
    It's just a part..... cutter still goes round and round....
    Aug 2004
    2849
    Well you could use a bi-metal hole saw, or you could chuck up a boring head on your drill press.
    Mar 2004
    847
    Quote Originally Posted by psychomill
    I've seen the Silver and Deming sets...what exactly are they that differs from normal drill bits?
    Holes saws tend to make really sloppy holes though - but that why there is sandpaper! I know I have a decent set in that size...
    Quote Originally Posted by ViperTX
    Boring head? Isn't that what happens after you get married?
    Seriously though, what is a boring head? I've seen them in catalogs, but I don't know how they work...
    35538
    Drill the holes in MDF with the forstner bits. Use a hole saw about 1/8" smaller than the finished hole size to rough out the hole. Clamp the mdf into position and use a router (slowly) with a pattern bit to clean up the hole. It's a bit hard to see, but that's how I did the holes in these plates. http://www.cnczone.com/forums/attach...tachmentid=644
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    35538
    Quote Originally Posted by JavaDog
    You'll wish.
    Gerry
    Aug 2004
    11
    I know this sounds stupid but it works really well. Spade bits (yes the cheap ones) work very well . I didn't believe it either but was amazed at how well they work , I've drilled a 50mm hole through 5/8 6061 Aluminum And it looks great (although I didn't mic it) it was a 2" spade bit that I ground down in a drill press to get it down to 50mm.
    Sep 2005
    3
    Maybe Im a little new aged but my suggestion would be to bring it to a shop that has bigger machines and ask them to drill out the hole for you? Would probably cost you less then what it would for a new tool and save you the headache.
    Dec 2003
    24223
    Do they have to be spot on 1" & 2"? Because if you know an industrial electrician, ask him if you can use his greenlee slug-buster, this is a panel punch for conduit holes in electrical panels, this makes a quick clean hole, although you can get 1" & 2" exactly, most electricians have the conduit sizes which are slightly under and slightly over those dimensions.
    Al.
    Albert E.
    Jul 2004
    93
    how about an adjustable hole cutter
    it uses a hss bit and a 1/4 bit for a pilot , have used in the past
    and it worked well
    just a thought
    IF ITS NOT BROKE YOUR NOT TRYING HARD ENOUGH
    Ashes to ashes , dust to dust , If it wasnt for Harleys the fast lane would rust.
    Aug 2004
    2849
    MILMANM's suggestion is to use a flycutter....they are kinda hard to find these days, but you can find them. If you were so inclined you could make your own.
    Jun 2005
    37
    I have used a spade bit as well, drilling up to 1 1/4" diameter, for making my bearing mounting blocks. I had to take it slow and just kept spraying it with WD40 (didn't have an real cutting oil) as I am using a cheapie drill press but it got the job done and it turned out surprisingly well. I have also used a 30mm forstner bit but that is really had on my drill press, the pulley belts were smoking by the time I got done. Thank goodness I only have one more of those to drill.
    Jun 2005
    37
    Just finished drilling my 2nd 30mm hole with a forstner bit & thought I would share a pic. Aluminum 6061, 30mm dia. & 3/8" deep. I took it a little slower this time. It took me about 30 minutes to finish it but no smoking belts on the drill press this time So for those of us who are not a machinist, working with a minimal of tools, there is hope. Well, I guess we'll see if it actually works when I finish this thing.
    Aug 2004
    2849
    It would probably help to have some of those Forstner bits that are carbide tipped.
    Mar 2004
    847
    Quote Originally Posted by MILLMANM
    how about an adjustable hole cutter it uses a hss bit and a 1/4 bit for a pilot , have used in the past and it worked well just a thought
    You guys mean something like one of these?
    FWIW, the Silver and Deming set I got from Harbor Freight = Total Crap. They are the crappiest bunch of crap bits I have ever seen. Not even close to balanced, chatter like you wouldn't beleive. I tried drilling a hole with one through some spare MDF I had laying around - I thought it was going to rip the chuck off of my press. It was so bad I got about an 1/8" into the wood before I had to stop. So, I seriously doubt these would work for the aluminum that I have.
    Aug 2004
    2849
    JavaDog....that is one ugly flycutter....but, yes that's the basic idea. I think the shield on the flycutter is kinda cute...
    May 2005
    1810
    Have you looked into using a UniBit? I have used Unibits to punch 7/8" holes in thick plate before I got my mill and I seem to recall seeing a large (possibly 1" - 1.5") diameter step bit at HD or Lowes - it may have been at Fastenall...?
    I think using a step drill would work well but driving power maybe an issue with a smaller drill press. If you were successful in getting the 1" hole in your plate, then you could bore it from there as previously suggested with an adjustable boring head.
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
    Aug 2004
    11
    $3
    Try a NEW spade bit, spend the $3, you will be surprised!
    Mar 2005
    1136
    reduced dia shank. came up on another board recently and someone posted this link, everything and more than you ever wanted to know.
    http://www.owwm.com/MfgIndex/detail.asp?ID=1017
    I don't know why the drill didnt' work for you, obviously there are lots of reasons why a drill doesn't work properly, but nothing specific to the SD style except maybe its taking a bigger cut and you need to run slower with the bigger dia cutter, stil those are basic to cutting and not SD specific. machine not rigid enough? weak set up? to big a cut? dill not sharpened properly? running to quickly. all these can produce chatter when drilling
    Mar 2004
    847
    Quote Originally Posted by mxtras
    Scott
    I haven't been able to find anyone local that sells boring heads. Guess I would have to order on online...
    Quote Originally Posted by beausdn
    I have sme new spade bits laying around, I am dubious, but I will give it a try on some scrap.
    Quote Originally Posted by Mcgyver
    I ran as slow as my press will go, and it still chatters like crazy. Even the lightest pressure and it just chatters and screams.
    Could it be that the cheap HF 'Drill Master' brand bits are junk?
Page 1 of 2 12
