586,533 active members*
2,982 visitors online*
Thread: Y Chatter
Results 1 to 8 of 8
    Nov 2010
    71
    Y Chatter
    Hi, Just learning the art of CNC. Got my machine to where I'm in the testing stages. Haven't tried to carve a piece of wood yet, just simulating to this point. All axis seem to run fairly smooth except the Y. When it gets to a point on the G-code where it's supposed to be cutting in a certain area It seems to chatter ( the best way I can describe it) or vibrate until it takes off on a longer run, then smooths out. Is that resonance or missed steps, or what do you think?
    Thank's Mike
    Is this on a curve or a circle? If so, it might just be taking the small steps until it gets to a straighter portion.
    My uncensored views and CNC Router planning: http://reinventingcnc.blogspot.com/
    Nov 2010
    71
    Small curves.
    Thanks MIke
    Aug 2008
    1166
    Do you have constant velocity turned on (assuming you're using Mach3)? If not and your curves are a series of small straight lines, that will give pretty clunky motion because the machine starts and stops at the end of each line (iirc).
    CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html
    Nov 2010
    71
    Yes I am using Mach3, and I'm just learning it. I don't know where constant velocity is located, or even if it's rurned on. I looked in motor tuning and didn't see it.
    So from what I've gathered from your input, this is nothing to be concerned about?
    Update---- I found it in General Config. and it is turned on.
    Thank's Mike
    Aug 2008
    1166
    It's in one of the settings screens - I don't remember off hand which one. If that's the cause of the stuttering it's nothing to be worried about - I'd just turn on CV mode so it will run smoother and faster. But if that's not it, it could be several other things that would be cause for concern.
    Aug 2008
    1166
    Looks like it's on the general tab. Here's more info:
    http://www.cnczone.com/forums/mach_s..._solution.html
    Nov 2010
    71
    Quote Originally Posted by jsheerin View Post
    Thank's, thats good info. Going to be gone a few days but will give it try when I get back and update on my progress. Man, there sure is alot to learn in this world of CNC.
    Later Mike
  1. help with x2 chatter,
    By Micro Milling in forum Benchtop Machines
    Last Post: 01-25-2010, 06:53 AM
  2. Chatter?
    By vectorsc in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-07-2009, 03:39 PM
  3. Chatter
    By TravisR100 in forum Haas Mills
    Last Post: 10-24-2009, 11:08 PM
  4. chatter
    By Claude Boudreau in forum DIY CNC Router Table Machines
    Last Post: 05-24-2009, 05:18 AM
  5. Chatter
    By gabeless in forum Hard / High Speed Machining
    Last Post: 07-14-2005, 05:09 PM
