586,438 active members*
4,269 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > HL-2 Alarm 134 "Low Hydraulic Pressure"
    Jan 2007
    122
    I have been fighting this machine for some time I have replaced the relay for the pump motor, there was a week leg running form the relay to to motor. I had a new shaft put in the pump due to the input spline was getting wore out, and now I still get an alarm.
    The pressure gauge shows 500+ on the tank but the machine keeps tripping due to the lack of pressure. Does anyone know off hand where the pressure sensor is?
    Jan 2007
    122
    Problem found, broken wire going to the pressure sensor
  1. Replies: 2
    Last Post: 09-10-2018, 09:21 PM
  2. SL20 Hydraulic pressure alarm???
    By gixxergary in forum Haas Lathes
    Last Post: 11-02-2017, 12:47 AM
  3. Alarm 120 "Low Air Pressure"
    By JoBwan in forum Haas Mills
    Last Post: 03-02-2016, 09:45 PM
  4. HL-2 Alarm 134 "Low Hydraulic Pressure"
    By dafowfidy in forum Haas Lathes
    Last Post: 07-11-2010, 06:05 PM
  5. Hydraulic Shear "PROMECAM"
    By nazidade in forum Uncategorised MetalWorking Machines
    Last Post: 12-11-2009, 09:26 PM
