586,489 active members*
1,459 visitors online*
Thread: Post problem
    Sep 2007
    34
    Post problem
    N10 G20
    N20 G0 G17 G40 G49 G80 G90
    N30 G61(CONSTANT CONTOUR OFF OR TURN ON W/G64)
    N40 (Deep Drill )
    N50 T1 M6
    N60 G43 0
    N70 S4000 M03
    N80 M08
    N90 G00 Z0.1250
    N100 X0.0000 Y0.0000
    N110 G83 X0.0000 Y0.0000 Z-0.8722 R0.1 F2.0 Q0.13
    N120G80
    N130 G00 Z0.1250
    This is the top portion of a program done in Rhinocam and using the Tormach post. When I try to run the program I get the error message:
    "Bug unknown motion code line 5"
    Anyone have an idea what is wrong?
    Etced
    Jun 2009
    195
    if you look at your post file for that machine under tool change , in ware it says first tool change at the end they have this line for tool hight offset " [SEQ_PRECHAR][SEQNUM][DELIMITER]G43[DELIMITER]H[TOOL_ADJST_REG] "
    you could remove it if that is something you don't need
    Tony
    Sep 2007
    34
    If I remove it the program will run. When I run with a offset it will be an issue.
    Ed
  1. post problem
    By CNC_FAN in forum Screen Layouts, Post Processors & Misc
    Last Post: 08-04-2010, 01:35 PM
  2. 4th axis post problem
    By Stebedeff in forum Mastercam
    Last Post: 03-19-2009, 06:59 PM
  3. sl20 post problem
    By johnmckeown in forum Surfcam
    Last Post: 08-02-2008, 01:29 AM
  4. Post Process problem
    By Wiseco in forum FeatureCAM CAD/CAM
    Last Post: 01-16-2006, 11:17 PM
  5. post problem
    By foamovercast in forum MetalWork Discussion
    Last Post: 10-18-2005, 04:27 AM
