I noticed when trying to cut 1/4" diameter circles using a 3/16" diameter bit with my techno gantry machine that I'm ending up with slightly oval shapes instead of a true 1/4" circle.
I'm getting 1/4" in the X axis but getting a little bit less (maybe .015" - .020") in the Y direction. It's just enough that it doesn't quite look right.
Is there anything that can be done about this?
I notice there's a little bit of looseness in the router's bearings (PC 7818) but that would give error in a circular (all directions) manner I would think.
I can push on the machine and get the Y direction (I have it set up like a Graph with Y) to move around .010" with a dial indicator base on the table and the needle on the gantry. But I would think just flex alone would allow for this much.
thanks!
Nick
