586,933 active members*
2,827 visitors online*
    Jul 2010
    Where to find Mach3 turn .set layout file
    Hey,
    I am after the screen layout file for mach3 turn to import into 'machscreen' to customise it. I am able to find the Mach mill files but not turn. Also would anyone be able to help me with creating a button that I could push which calibrates the machine ie goes to both the z axis home switches and x home switches. This will be run at startup to ensure the machine is calibrated. I am using stepper motors therefore they have no encoder so if the machine is bumped whilst its off that could cause problems hence the calibrate button.
    Many thanks,
    Lachie
    Turn files are .lset
    Try 1024.lset
    Jul 2010
    Thanks for that.
    That has worked perfectly!
    All I need to do now is develop a button with some code attached to calibrate the machine. Could you offer any guidance?
    thanks
    Download the manual for my new screen, and the last two pages have info on creating homing scripts. The CNC Woodworker - Mach3 2010
    When you add the button, set it for VB script, and add the script in Mach3 using Operator > Edit Button Script.
  1. mach3 turn simulation?
    By tracebender in forum Mini Lathe
    Last Post: 02-23-2010, 09:57 PM
  2. Turn file 90 Degs.
    By cwebs in forum G-Code Programing
    Last Post: 10-11-2009, 07:09 PM
  3. File tree layout
    By Chipload in forum Uncategorised CAM Discussion
    Last Post: 06-27-2009, 02:22 AM
  4. Help to find xml file (MACH 3)for MAXNC 10CL-B
    By DennyNY in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-13-2008, 01:02 AM
  5. Is There A Pdf File Just For Mach2 Turn
    By CATCH22 in forum Mach Lathe
    Last Post: 08-03-2005, 03:35 AM
