586,395 active members*
2,857 visitors online*
Page 1 of 3 123
Results 1 to 20 of 52
    79
    Build thread X3 and G0602
    Hi all. I am about to Convert my X3 mill and my g0602 lathe to CNC control. Here are all of the threads that I read about converting the X3:
    Bob Berg
    09-14-2004
    DIY
    Servos with 5/8" 5 TPI Rockford Standard Grade Ballscrew and Ball nuts
    CNC Conversion of a Sieg X-3 Mil
    jl123
    07-06-2006
    CNC Fusion kit
    3 Gecko 202 + G100
    Pics of ball screw ends on page 11
    http://www.cnczone.com/forums/bencht..._them_all.html
    Greolt
    08-15-2006
    Syil conversion kit
    http://www.cnczone.com/forums/syil_p..._kit_syil.html
    S_J_H
    09-24-2006
    DIY
    http://www.cnczone.com/forums/bencht...its_alive.html
    cadmonkey
    06-08-2008
    DIY NOOK screws
    G203V drives
    300 oz, 300 oz, 600 oz 2.6:1 for x,y,z
    http://www.cnczone.com/forums/bencht...onversion.html
    Matt McColley
    03-12-2009
    DIY screws
    First attempt at N34 Z axis
    http://www.cnczone.com/forums/bencht...d_odyssey.html
    MRM RCModels
    02-26-2008
    CNC Fusion x3 delux kit with Crevice Reamer G540 option
    3 Gecko drives 203V
    2 425 oz Stepper Motors (x and y)
    1 640 oz Stepper Motor (z)
    1000W Power Supply w/ 12v & 5V outputs (1)
    http://www.cnczone.com/forums/bencht...usion_kit.html
    Eternal
    08-11-2010
    G540
    2 Keling KL23H2100-35-4B 381 oz (x and y)
    1 Keling KL34H295-43-8A 906 oz N34 motor for Z
    Keling KL-350-48 48V/7.3A PSU
    http://www.cnczone.com/forums/bencht...ill_build.html
    CreviseReamer
    Date unknown
    Page 29
    And here are all I have read about the G0602:
    derekbackus
    Start date:06-10-2008
    Started with:
    CNC4PC C11 Multifunction Break-Out-Board
    - CNC4PC C21 Voltage Regulation Unit (supplies power to the C11 board)
    - Xylotex 3 Axis Bipolar Stepper Motor Driver "Kit" With Power Supply, 269oz/in Steppers.
    then switchwed to Gecko Drive
    http://www.cnczone.com/forums/vertic...onversion.html
    Crevice Reamer
    Start date: 06-02-2010
    Stock screws
    G540
    Modified Keling 270 motor for X
    Keling 381 motor for Z
    Keling 48V PSU
    Hall Effect indexing sensor and Home switches.
    Steelpolish
    Start date: 12-08-2009
    2 Gecko 203V
    2 425 oz.in. Nema 23 Stepper Motors
    If you know of any other threads that I should look at please let me know.
    79
    For electronics and motors I am thinking about using:
    X3 Mill:
    G540 3 axis package (one G540 + one NEMA 34 KL34H295-43-8B,
    906 oz-in +Two NEMA 23 KL23H2100-35-4B (1/4” Dual shaft with a
    flat) 381 oz-in + one KL-600-48 48V/12.5A 115V /230V
    power supply): $581.95
    G0602 Lathe:
    The same G540 and Two NEMA 23 KL23H2100-35-4B (1/4” Dual shaft with a
    flat) 381 oz-in.
    I would have ordered these today but as usual American companys like to make things difficult for us Canadians so I have to email for a quote first and I am now waiting a reply.
    79
    I am thinking about ordering ballscrews from these guys:
    3 RM1605-250/680/900mm ballscrews + 3 sets BK/BF12 on eBay.ca (item 250543639705 end time 31-Dec-10 06:03:55 EST)
    They may be a long way away but all I have to do is click the button and they will ship to me right away. Any opinions on these screws?
    79
    I want to use pulleys to drive the lead screws on all the axis of the mill to keep the size of the work envelope down. Similar to the machine shown here PROMiCA - CNCKits. Can someone give me some advice on how to size the pulleys and belts for this?
    What pulleys are used for the cncfusion kit with the crevice reamer option for the z axis on the X3?
    79
    Now I am confused about timing belts. Which is the best material for this application; urethane, neoprene, or silicone? And which is the best tension member; fiberglass, polyester or kevlar?
    79
    Need help with timing belts
    I am suprised that I did not hear back from Keling yet. Does anybody know if they are closed for the holidays?
    I am also surprised that nobody had anything to say about the timing belts. Its like that information is secrete or something. I have spent hours searching this forum and most threads that metion timing belts say they got them from SDP/SI. But any of the threads that i have read that talk about material say that the best material for tension member is steel but that is not a choice at SDP/DI. So just what are people using?
    7063
    Quote Originally Posted by SmoggyTurnip View Post
    For the very light loads these machines see, anything will do. The belt material won't make one bit of difference in how the machine operates.
    Ray L.
    79
    Quote Originally Posted by HimyKabibble View Post
    Ray L.
    Thanks for your input HimyKabibble. I was thinking of using .200 inch pitch pulleys with 14 teeth for x and y axis because I can get them from McMaster Carr right away. They would be a simple 1 to 1 ratio for both the x and y axis. Do you think that would be a reasonable choice?
    7063
    That will work fine. Take a look at sdp-si.com. They have everything you need. Don't go over-size on the belt size either. My knee mill is done with 15mm wide belts, even the XL belt moving the 700 pound knee. Works just fine. These belts are one helluva lot stronger than most people assume.
    Ray L.
    Mar 2004
    1806
    Ray L.
    On my RF-31 I use XL-037 belts also and found out the hard way that weaker (to a point) is better. I had a hard crash (before I got smart and put limits on this servo driven machine) and fortunately I only lost a $4 belt when it acted like a fuse and broke rather than something else!
    Art
    79
    Thanks HimyKabibble and Bubba. This is great info. I got a response from Keling and I ordered the electronics. 5 steppers, 1 power supply, 1 G540 controller. Total cost was $745.00 including shipping to Canada. I think that is a great deal.
    79
    I just ordered 5 ballscrews from linearmotion2008. 3 for the X3 mill and 2 for the G0602 lathe.
    RM1605-400mm
    RM1605-450mm
    RM1605-700mm
    RM1605-900mm
    RM2005-1000mm
    All with antibacklash nuts.
    79
    Total cost for 5 ballscrews was $349.00 including shipping.
    79
    Electronics arrive
    Got my electronics from Keling yesterday. That was quicker than I thought. So far all I did was put 110 volts to the power supply (KL-600-48) and check the output voltages. 48 volts was OK (48.00) , 5 Volts was OK (5.00) , but the 12 volts output measured only 3.4 volts. I didn`t even know there was a 5volt output or a 12 volt output so maybe this is normal? Does anyone know what the current rating for the 5 volt output is? Is there suposed to be a 12 volt output on this power supply?
    Jan 2010
    2141
    The docs don't specify either 5V or 12V outputs, but Keling is not the manufacturer of the power supply, so maybe they supply different base models from time to time depending on what they can source from their Chinese distributors.
    http://www.kelinginc.net/KL-600-48.pdf
    Upon looking at your photo, it sure appears like the power supply that they sent you claims to have 5V and 12V outputs.
    79
    oops
    I thought I ordered 2 extra 381 oz-in KL23H2100-35-4B for my lathe but I ordered two 425 oz-in KL23H286-20-8B instead (Copy and paste without reading I guess) . They should work though. I did want to have the x and y the same on both the mill and lathe so that I wouldn't have to adjust the trim pot on the g540 when switching from the mill to the lathe. For now I will be able to test out both and see which is best and then I will re-order so that I can have them all the same and I will use one of the extras for a 4th axis and one for some future project.
    Oct 2008
    1632
    It actually would be nice to know if those have 12 and 5 volts also like the ones in the picture on Kelings site, of course he really doesn't provide good accurate descriptions and no matter what power supply you click on they all have the same picture. Having the 5, 12, and 48 all in one box saves lots of room and wiring.
    Richard
    Quote Originally Posted by doorknob View Post
    79
    Steppers work on first try!
    Today I wired up my steppers. This is my first experance with steppers. Everything worked without a single hitch! To set the current level for the motor I wired a 5K pot to pins 1 and 5 of the DB9 connector and adjusted the resistance to 3.5K-ohms. I downloaded Mach3 and ran it for the first time today. I spent alot of time watching the mach3 video tutorials on Artsofts web site which were really great. I was able to get my steppers going forward, and reverse at all different speeds making pretty noises etc. Things are looking good. Now waithing for ballscrews from china.
    79
    Ball screws arrive
    The shipper called me today and I have a package from China. I could pick it up today if I want but they will drop it off at my workplace tomorrow (no time to get it today). I don't have to pay anything to get it, I just have to sign for it. I only clicked on the button 10 days ago - amazing. I hope everything survived the trip. I also got my timing pulleys and belts from McMaster Carr so it should be a fun weekend.
    79
    Ball screws arrive
    Here is what the ballscrews look like as I received them today. They do not have detectable backlash when examining them by hand. Those 5 little things at the bottom right hand corner are 5 grease nipples that I almost missed when unpacking the screws. I have no idea how they attach to the ball nuts yet. I now have all of the major components for both my conversions. All the steppers, electronics, ballscrews, timing belts and pulleys.
    Total cost so far $1301 including shipping. This is for 2 machines.
    Attached Thumbnails Attached Thumbnails Ball screw packaging.jpg   Ball screws just opened.jpg
Page 1 of 3 123
  1. My JOES build thread......
    By craigjh in forum Australia, New Zealand Club House
    Last Post: 04-06-2012, 09:54 PM
  2. TXFred's X2 build thread
    By TXFred in forum Benchtop Machines
    Last Post: 04-21-2011, 01:10 PM
  3. MTW PM20LV Build Thread
    By Enraged in forum Benchtop Machines
    Last Post: 11-30-2010, 06:31 PM
  4. CNC guitar build thread.
    By Drools in forum Musical Instrument Design and Construction
    Last Post: 11-23-2010, 05:53 AM
  5. Maybe a New TAIG CNC Enclosure: Build Thread
    By CROSSHATCH in forum Taig Mills / Lathes
    Last Post: 05-02-2008, 06:54 AM
