586,594 active members*
2,916 visitors online*
    Mar 2009
    76
    Helical Milling Citizen L632
    Does anyone have any proving code for helical milling on a L32? I am going to mill a thread using a single point thread mill & want to get started on the right foot.
    I recently tried helical milling on a L720 and couldn't seem to get it to work.
    Feb 2008
    267
    arcing in and arcing out aside, it's pretty straight forward.
    Code:
    G1 W.125F???
    G2K-.125U-.062F(U IS YOUR THREAD PITCH IN DIAMETER)
    G2K-.125U-.062
    G2K-.125U-.062
    G2K-.125U-.062
    G1W-.125
    G0X???
    HTH
    Good luck.
    Control the process, not the product!
    Machining is more science than art, master the science and the artistry will be evident.
    304
    (HELICAL MILL )
    (#511=DIAMETER OF CIRCLE)
    #511=*
    (#512=CENTRE OF CIRCLE)
    #512=*
    (#513 =FEEDRATE)
    #513=*
    (#514=TURNED DIAMETER)
    #514=*
    (#515=DEPTH OF CUT)
    #515=*
    (#516=NO OF SPIRAL STEPS)
    #516=*
    M5 G98
    M80 S3=*
    T**00
    M18 C*
    G50 W-0.591
    G0 X#814+0.025 Y0 Z#512 T*
    X#514+0.025
    G19
    G1 G41 W#511/2 F#513
    G3 Z#512+[#511/2] X[[#514+0.025]-[#515*2]]V0 K-#511/2 P#516
    G1 G40 Z#512 F40.
    G18
    G0 X#814+0.025 T0
    G50 W0.591
    M20 M82 G99
    From CNC Wizard.
  1. Helical Milling on VR-40
    By abealz in forum Okuma
    Last Post: 10-06-2009, 01:10 PM
  2. Helical Milling
    By mikepaubuchon in forum CNC Swiss Screw Machines
    Last Post: 09-27-2009, 02:56 AM
  3. Helical Milling
    By binzer in forum GibbsCAM
    Last Post: 03-30-2007, 10:39 PM
  4. helical milling
    By hogman in forum GibbsCAM
    Last Post: 04-22-2006, 02:15 AM
  5. Milling with a Citizen C16
    By Koalas in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-22-2005, 08:22 AM
