Ok, so I have Mach 3 set up with the tool length measurements for all my common tools in repeatable Tormach holders. These have all been measured from the face of the spindle. I have the g-code post processor set up to look like this "TXXX M2 G43 H2" where XXX is the tool number every time a tool change is exported.
Now the stupid question - how do I properly tell mach 3 what the surface of the part is?
I don't have a dedicated set up tool currently. I broke it by driving it into the table about 30 minutes ago and am still kicking myself over that stupidity. I assume I can make one of my drill bits that. If I do pick a dedicated tool, do all the lengths in the tool table become an offset from the length of that tool? IE: shorter tools are a positive distance and longer tools are a negative?
Also, assuming I do all that, how do I properly orient Mach 3? There is a touch off tab but that doesn't seem quite right to me.
Thanks for all the help, it seems this is obvious but I'm just not quite getting it!
-Mike
