586,633 active members*
3,062 visitors online*
Results 1 to 20 of 30
    Apr 2008
    15
    Ripples in my moulds
    Hi Guys,
    I need some help from the experts!!
    I have been maching some MDF moulds for a model that a friend has designed. I am using a home built Rockcliff Model A, Mach3 to run it and Vectric 3D to generate the G-Code for the moulds.
    Iam currently using a 10mm Radius Bit for the rough cutting and a 3mm Ball Nose for the finishing cuts.
    The rough cutting seems to be fine, (800mm/min, 3mm pass depth and 33% stepover, cutting along the X-Axis) see photo IMG_2991.jpg.
    The finishing cutting (800mm/min, 1.5mm pass depth and 9% stepover, cutting along the Y-Axis) seemed to leave some ridges, which I put down to using a Radius Bit for the rough cuts.
    I gave the part a number of good epoxy resin coats, using a hot air gun to wick the resin into the MDF, until I ended up with quite a bit of excess resin on the surface - more than enough to fill the ridges.
    I re-ran the finishing cut and have ended up with more ridges - see photos, IMG_2992.jpg and IMG_2993.jpg.
    Does anyone have any clues as to what is causing them? Is it the 3mm tool flexing? Is the feed rate too high? Could the part be moving slightly on the machine bed? Is it something else?
    Please help,
    Martin.
    Attached Thumbnails Attached Thumbnails IMG_2991.JPG   IMG_2992.JPG   IMG_2993.JPG
    Could be a mechanical issue, like a loose setscrew maybe.
    I use a 1/8" ballnose bit at 150-170ipm (3800mm) with glass smooth results. If anything, you're feedrate is on the low side.
    Apr 2008
    15
    I just zoomed in on the Cut3D preview and can see what appear to be the ridges.
    Any ideas as to what settings I might need to change in Cut3D to stop these ridges?
    Martin.
    Apr 2008
    15
    Just had a look at the original Solidworks .STL file.
    I think I can see some ridges there as well! Now I'm really out of my depth, how do I get round this problem?
    I guess I wasn't sure what you were talking about. You need to change your SolidWorks .stl export tolerances to get a smoother finish.
    Oct 2010
    65
    As Gerry mentined the STL looks like it needs better precision, in solidworks after clicking a save as, STL the pop up window will show an options button, you can set the precision higher before exporting the STL,
    Apr 2008
    15
    Markwind,
    I will give it a go. I was thinking I was going to have to wade through the instructions, and online, to find out how to adjust the settings.
    You have just saved me a lot of time. As soon as the wife has left for the post Christmas sales, I will give it a go.
    Many thanks,
    Martin.
    Apr 2008
    15
    Time for the next installment of this Xmas story!!
    Well the designer of the moulds, and I, have had a play and have wound the resolution of the .STL file right up. It has now gone from 43KB in size to 559KB. No ridges are visible when displayed in SW or Cut3D.
    I ran the finishing cuts again using the updated, larger, .STL file as a starting point, but to no avail. I still have ridges in my mould. I tried the finishing cuts in the X-Axis, in the Y-Axis and at a 45 degree angle. All had ridges.
    I am now somewhat stuck. Is it a software issue or a mechanical one?
    I have spoken to the designer and he is happy for me to post the Canopy Mould .STL file on the forum. What we are hoping is that there is someone out there that has the time, and spare capacity on their machine, to convert it to G-Code and cut a test piece. If ridges appear in their version of the mould then the problem is with the software, if no ridges are present, then it must be a mechanical issue with my machine!!! (The part is only 187mm by 70mm by 52mm).
    Is there anyone able to help out?
    Martin.
    P.S. This is also posted on RCGroups.
    Attached Files Attached Files
    Feb 2009
    2143
    When you cut in X compared to in Y, are the ridges in the same direction? If not, then it is the scallop of the tool making the ridges. To get rid if it, you need to decrease the size of your stepover. If you use a 1/8" ball end mill, your finish pass should be done with a stepover of around 0.002" if you want a very smooth finish. You would do well to do the final pass in multiple directions, as well, for the best finish.
    Apr 2003
    312
    One additional thing to insure is that your cutting table/surface is perfectly perpendicular to your router shaft/cutter axis.
    Steve
    aka BOOMER52 >>> http://www.rcgroups.com/forums/member.php?u=159693
    Apr 2008
    15
    mcphill,
    The ridges stay in the same direction, regardless of which way the cutter travels. It is almost as if the MDF had extra hard layers within it!!
    Senna,
    The machine is as perpendicular as I can get it (about 98-99%) - if I have to rebuild the Z-Axis I will try to get it even better.
    Martin.
    Oct 2010
    65
    After re-reading your message
    Quote "The finishing cutting (800mm/min, 1.5mm pass depth and 9% stepover, cutting along the Y-Axis) seemed to leave some ridges"
    Sorry, for not looking at this in the first place, but after doing some math, using a 1.5mm deep x 9% stepover of a 10mm cutter is much too coarse for a fine finish,
    I primarily work in inches, and for a smooth finish in wood, you need anywhere from about .002"to .010" inch stepover in all directions
    Which would translate in metric to about 0.05mm to 0.20mm (if my math is correct)
    It going to take longer to cut but you should see a much improved looking part
    Apr 2006
    3498
    I think it may be the problem in CUT3D import.. Just ask Brian, i think the import of STL in Cut3D is not upto-the-mark..i.e. the High mesh density file are optimized and i have similar experience.. I have laser scan the Rooster model and when it was imported in the Cut3D it has similar ridges..
    Just check, may be it is one of the possibility beside mechanical things...
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
    Apr 2008
    15
    Markwind,
    The finishing cut was done with a 3mm ball nose bit (9% = 0.27mm)
    Apr 2008
    15
    Khalid,
    In a way I hope you are right about the problem being a Cut3D import.
    What I need is for someone to run my G-Code and see if the problem occurs. If it does, then the software is the cause. If not, it must be mechanical!
    The code is posted on RCGroups;
    RC Groups - View Single Post - Ripples in my moulds
    The whole thread is here;
    Ripples in my moulds - RC Groups
    Apr 2006
    3498
    Do you have any STL viewer?..Just check the model in it.. If it has Faceted surfaces then this is the problem of the Export.. If it seems smooth but seems faceted in CUT3D, then this is the problem in Cut3D...
    You can download MeshCam and check in it too???
    Apr 2006
    3498
    Mar 2004
    4
    A better option would be to check in Cut3D for other import options other than STL I have found STL to be faceted by nature so if you can import solids or surfaces in parasolids or IGES you have a chance for much higher precision surface than from STL. Solidworks can output most model format currently in use. When I was 3D contouring graphite trodes 3000rpm 76mm/min feedrate and .07-.13mm stepover with 10mm spherical cutter would generate a glass smooth surface on graphite. You will need to convert the proportion of rpm/feedrate/ to the rpm you need for wood
    Apr 2008
    15
    Khalid,
    The original STL file has had it's resolution upped to the max. No faceting problems to be seen. I can view the files easily in SolidWorks - when I can get access to it!!
    What I really need is for someone to take the time to run my code and ascertain if the ridges are in the code or not.
    Meshcam looks good, but I am loathe to spend another $175 on a piece of software that may not cure the problem, I know I can get a 30 day free trial, but I will only use that as a last resort.
    Martin.
    I believe that Cut 3d only works with triangular mesh files, like .stl's, dxf, obj, 3ds,...
    Just a thought. How rigid is your machine? On my machine, I get ripples in the edges of 2D cuts, due to leadscrew whip. They are repeatable, and always in the same place.
  1. Injection Moulds
    By jatinderr in forum News Announcements
    Last Post: 12-03-2009, 06:39 AM
  2. x3 for 3d moulds?
    By nicrump in forum Syil Products
    Last Post: 12-29-2006, 03:09 PM
  3. Pictures of your Moulds
    By MBG in forum Casting Metals
    Last Post: 11-05-2006, 12:37 AM
  4. Router for 3D moulds
    By erazz in forum Commercial CNC Wood Routers
    Last Post: 10-23-2006, 07:32 PM
