586,655 active members*
3,466 visitors online*
IndustryArena Forum > CAM Software > Mastercam > centre of rotation of B axis and C axis
Results 1 to 7 of 7
    Sep 2010
    135
    I got this horizontal 5 axis with B and C axis, C axis is seating perpendicular on B axis [horizontal table] , the centre of rotation of C axis is off [2 millimetres] in relation to the B axis [horizontal table], two millimetres is nothing but for some works that we do, it is a big deal...
    where is the proper place on matercam to input the difference?
    WCS origin?
    Machine definition file?
    thank you guys and happy christmas
    Apr 2007
    9
    Could you show in geometric? I don't understand!
    Jun 2006
    48
    that should be changed in the machine definition, when the machine configuration manager pops up goto the machine configuration window, right click on a or b axis and select properties you should see the fields for axis center of rotation
    Sep 2010
    135
    Quote Originally Posted by brandou10l View Post
    hi,
    I changed that on machine defenitions but the code outputs the same..
    theres no changes at all...
    I don't understande ...
    can you think of anything else?
    thank you...
    Dec 2004
    44
    Quote Originally Posted by PRINT_FX View Post
    It can be in different places and very depend what post you run.
    Check misc. reals tab in OP or open post and read comments there
    Happy christmas!
    Sep 2010
    135
    Quote Originally Posted by ak762 View Post
    Happy christmas!
    hi
    can you please detail >Check misc. reals tab in OP
    my post does not mention nothing about C axis set-up etc.
    thanks
    Dec 2004
    44
    hi
    thanks
    I mean in milltoolpath operation you can check misc values. it is my assumption only because very depends how your post was composed
  1. Required to delete axis from Turning centre
    By Vishal N in forum Servo Motors / Drives
    Last Post: 04-13-2024, 12:10 AM
  2. VH 65 A axis rotation
    By timo2le in forum Fadal
    Last Post: 09-08-2018, 10:13 AM
  3. Replies: 1
    Last Post: 07-12-2010, 01:45 PM
  4. Formula for B axis rotation on machining centre?
    By fitzpatrick2362 in forum Mechanical Calculations/Engineering Design
    Last Post: 11-25-2009, 04:36 AM
  5. 5 Axis Machining and 6 Axes Turning Centre available
    By syamin in forum News Announcements
    Last Post: 02-16-2009, 01:25 AM
