586,966 active members*
2,028 visitors online*
Thread: X Y Z Screen
    Feb 2010
    X Y Z Screen
    I finally got some fuses and got my Mori MV 35 back in operation.
    Power up and everything is fine and working.
    I accidentally over traveled Y axis with the wheel. The screen changes from the X, Y, & Z screen that reads the co-ordinates as the table and Z column moves to the alarm screen, everything normal as it should be.
    alarm 220 Y travel limit goes on, I reverse table direction with wheel and press reset and alarm goes out, OK and Normal
    The question is should the X Y & Z screen now come back up or do I need to push or re-set something else?
    I just turned off the machine and turned back on and got the X Y Z screen back up. There must be someway to return from the alarm screen to the normal X Y Z screen?
    Mar 2009
    17
    What type of control are you using. Brand? Model?
    Feb 2010
    Whoops
    Fanuc 6Mb control
    Mar 2008
    169
    Press POS Key.
  1. New Screen set for my touch screen
    By Scott_M in forum Tormach Personal CNC Mill
    Last Post: 08-17-2010, 01:37 PM
  2. screen
    By larry53 in forum Computers / Desktops / Networking
    Last Post: 11-29-2009, 12:03 AM
  3. Homemade Screen Printer/Silk Screen
    By Sbthomas13 in forum Machine Created Art
    Last Post: 02-14-2009, 01:35 AM
  4. I think the screen on my 6T is going out
    By protrxrptr17 in forum Fanuc
    Last Post: 11-07-2008, 01:23 AM
  5. Replies: 6
    Last Post: 07-13-2008, 11:28 PM
