Can anyone tell me the proper way to fuse my electronics? I am using gecko G201's with 4.2V--4.7A steppers, 4 Wire. Do I fuse between the capacitor and the gecko on the "-" side as shown here
http://www.cnczone.com/forums/attach...achmentid=7925
or do I fuse between the geckos and the motors on each phase? or maybe both???
Also, I would assume if one is fusing the motor phases then you would use slow blow fuses slightly higher then the motors rated amps? For example, my motors (again 4.7A) I would use 5A slow blow on each phase, Would that be correct?
Thanks for any advice you could offer
-Allen
