587,006 active members*
2,922 visitors online*
Page 1 of 22 12311
Results 1 to 20 of 421
    Jul 2006
    1256
    DMM Tec Servos
    Post your experience or questions on DMM servos.
    Larry
    L GALILEO THE EPOXY SURFACE PLATE IS FLAT
    Jul 2006
    1256
    Jul 2006
    1256
    What is the max voltage rating on the Dyndrives and 900W servos?I have a 60V supply.
    Larry
    15362
    lgalla
    It's best not to go over 48v for the Dyna Drive 2 50v max, There is a 100v drive in progress, but are not sure when it will be made available for sale, That will double the performance of that same motor
    Mactec54
    Jul 2006
    1256
    Here is possibly the stupidest question ever on the zone.If the servos are A/C,why is the power supply D/C.Are the A/C servos brushless?Sorry for the stupid questions as there is little information on A/C servos on the zone.
    Larry:withstupi
    24223
    Larry, Simply that a DC supply is needed in order to electronically create the variable frequency output as in AC sinusoidal or the switching pulses for BLDC.
    VFD's also have use the same principal for 3 phase induction motors, i.e. create 3 phases from a DC supply.
    Here is the BLDC commutation.
    http://users.tinyworld.co.uk/flecc/4...otor031102.swf
    AC and BLDC motors are built practically identical.
    Al.
    15362
    lgalla
    The motors are AC servo's & brushless, It's like when you have a VFD you put AC into the drive, but you don't get AC out of the drive,you get DC for the supply to the AC induction motor, These & other AC servo motors run the same way
    Mactec54
    Mar 2011
    525
    I am considering using the 3 axis system on a RF31 clone. I would love to hear more from anyone using the system.
    15362
    kregan
    There are a lot of Zone members that have the Dmm system, They have there system running, but have not completed there machines
    You can see the Dmm system working [nomedia="http://www.youtube.com/watch?v=YZb7nJMx_68"]YouTube - cncvids 028.AVI[/nomedia]
    The build is here http://www.cnczone.com/forums/diy-cn...kes_first.html
    This is another Build http://www.cnczone.com/forums/cnc_wo...5_cnc_cut.html
    Mactec54
    Oct 2006
    205
    I might be one of the initial users of the DMM system. I bought my DMM system in July 2010 and will be coming up to 1 year using my cnc router on a weekly basis. I'm only a home shop machinist and not into production.
    I have a build log and started talking about servo choices and DMM here: http://www.cnczone.com/forums/diy-cn...s_first-5.html
    My initial questions about the DMM system were:
    Aren't AC servos only used in very high end machines?
    How can DMM price their AC servos the same as DC servos.
    The DMM encoders have some very high encoder counts compared to other servo encoders.
    Aren'e servo motors hard to tune?
    What kind of service will I get from a new company like DMM?
    I was pleasantly surprised to learn that, Yes, AC servos are typically used on big expensive machines and the DMM AC servos are a scaled down version of the same.
    I still don't know how DMM set the prices competitively with other servo motors. I'm guessing a close association with the manufacture as well as a large wholesale order. All I know, is that I took advantage of the prices.
    I'm not into production and encoder counts was not a big concern for me. I just knew that more is better. It was a bonus for me that the encoders were pre-installed on the AC servos and pre- wired too.
    I found out that tuning these servos was not as complicated as I have read in many cnc zoners post. DMM supply's some simple software that tunes the servo's perfectly. You just need to follow the documentation carefully.
    The biggest advantage with going with DMM was working with their tech support. I asked some pretty dumb questions, not just once, but two or three times. Each time my question was answered in a timely manner and thoughtfully in a way only a novice electrician would understand. In other words, they didn't make me feel as if I was wasting their time.
    Knock on wood, but I have not had any problems with by servos or other components from DMM. I'm planning on a building a 4th axis using the same AC servos.
    Sorry I cant quote any technical specification with the AC servos. That's not my thing, but making chips is!
    Rod
    San Francisco
    Mar 2011
    525
    Can you repost those build thread links... they both say page not found?
    Nice video!
    kregan
    You can see the Dmm system working YouTube - cncvids 028.AVI
    The build is here http://www.cnczone.com/forums/servo_...nc_router.html
    This is another Build http://www.cnczone.com/forums/servo_...r_project.html
    15362
    kregan
    Try the links now, I don't no what happened to them, They looked ok when I posted them, they are working now, Plus Rod just posted, one of the links is his build
    Mactec54
    May 2010
    307
    As someone who is planning on purchasing four of the 900W motors, I'd be very interested in the 100V driver they are working on. Do they plan to release a power supply to pair with it?
    I don't plan on purchaing until 2-3 months from now. Think it might be available by then? I would hate to buy the 50V version and then have the 100V come out shortly after. Also how much of a price increase are we looking at (ballpark)?
    15362
    giz
    At this time The 100v Drive Has changed track, it now will/is 120/240V AC input, there will be no need for a power supply, but this drive is just in the build stage, the front end is all done,
    The Dyna-2 has also changed, & is now a max of 75V DC it would be good to run around 65V DC to the motors, These are being made right now, This will improve the performance of the 7.2Nm motor as well to around 1350RPM
    Mactec54
    May 2010
    307
    Wow, very interesting! I guess we'll see what is around 2-3 months from now.
    Mar 2011
    Hi Mactec
    I have a new build started and will be using DMM Technology package
    "Peak 7.2Nm(1015 OZ-In) high torque AC servo motor, 3 Axis CNC kit for MACH"
    With the new drives being made, you said the rpm will be around 1350, but what about the torque?
    I included a picture of the system case I'm putting together.
    Heavy
    Mar 2011
    Mactec,
    I was looking at torchmates machines and they give you two motor options for the same machine. You can order it with either a 380 oz. inch. stepper motors or 152 oz. inch. servo motors. I'm curious, do you know if a AC Servo torque 1015 oz = 1015 oz Stepper motor? Based on what torchmate offers it seems as though a servo motor is more than twice as strong as a stepper motor.
    Heavycnc
    Mar 2011
    525
    I have the price quote for the 3 axis 300 watt setup and will order as soon as I can get payment details.
    15362
    heavycnc
    Servo motors are rated in watts & N-m or in-lb, Only very small servo's will have a N-m oz-in rating listed, although you do see people using oz-in they have converted the in-lb to oz-in,to try & get a comparision, But this does not compare the two,in terms of performance
    The one you posted at 152 oz-in would be around a 250watt motor, If the 152 oz-in is the rated output, but most likely is a DC servo with brushes, These are not the same performance as AC servo's
    A Servos that is say 400W (.53hp) Rated output 181 oz-in, Peak output 542 oz-in
    Mactec54
    Jul 2006
    1256
    Will a pair of DMM 900Watt servos move my 500lbs gantry at decent speeds and have enough torque?I understand it is a vague question.I would be using 12DP R&P with 2"
    pinion
    Larry
Page 1 of 22 12311
  1. Propriatary AC servos into universal AC servos with an encoder swap?
    By SwampDonkey in forum Servo Motors / Drives
    Last Post: 05-10-2013, 07:22 PM
  2. Servos for 604
    By excello in forum Uncategorised MetalWorking Machines
    Last Post: 03-16-2012, 08:21 PM
  3. EMC and servos
    By RP Designs in forum LinuxCNC (formerly EMC2)
    Last Post: 05-08-2009, 05:06 AM
  4. AB servos
    By macgeek10 in forum CNC Machine Related Electronics
    Last Post: 05-28-2006, 05:05 AM
  5. Servos
    By cncadmin in forum Mach Software (ArtSoft software)
    Last Post: 07-17-2004, 07:19 PM
