587,030 active members*
3,517 visitors online*
Page 22 of 22 12202122
Results 421 to 421 of 421
  1. #421
    15362
    Re: DMM Tec Servos
    Quote Originally Posted by Bl@ckrat View Post
    Glenninvb
    how are you powering your BOB ? separate 5v ? or on a usb lead ?
    You can use the USB connection or a 5vdc supply, But only one can be in use, your choice
    Just a phone charger that is all that is needed for the 5vdc connection, or if you have a 5vdc power supply in your system you can use that
    Photo attached showing the 5vdc connection & a jumper on the E-Stop terminal block which you will need to make it work, or use the E-Stop correctly wired
    Mactec54
  1. Propriatary AC servos into universal AC servos with an encoder swap?
    By SwampDonkey in forum Servo Motors / Drives
    Last Post: 05-10-2013, 07:22 PM
  2. Servos for 604
    By excello in forum Uncategorised MetalWorking Machines
    Last Post: 03-16-2012, 08:21 PM
  3. EMC and servos
    By RP Designs in forum LinuxCNC (formerly EMC2)
    Last Post: 05-08-2009, 05:06 AM
  4. AB servos
    By macgeek10 in forum CNC Machine Related Electronics
    Last Post: 05-28-2006, 05:05 AM
  5. Servos
    By cncadmin in forum Mach Software (ArtSoft software)
    Last Post: 07-17-2004, 07:19 PM
