586,144 active members*
3,748 visitors online*
Results 1 to 7 of 7
    May 2006
    93
    Unhappy Communication
    I am trying to send a program from my laptop to my VMC40 1989 model. When I send the program to the VMC it produces a bunch of Errors on the controller. I am using Part Master Comms by Dolphin Cad/Cam. The program I am trying to run is also produced by Dolphin Cam.
    PS. I am also using Iogear USB to Serial adapter with a DB9 t0DB 25.
    Jan 2004
    3154
    1 - Is your DB9 - DB25 wired as is shown in the manual?
    2 - Most of the time the USB emulators do not work or have occasional issues (I used 1 for a few years but started having too many errors). A proper (laptop) card is $150 and is HIGHLY recommended.
    3 - Are your com settings set as per the manual.
    www.integratedmechanical.ca
    May 2006
    93
    DarBee you were right about the USB emulators. I pluged the RS232 into my old Dell desk top and it worked fine. Do you think I can have someone install a DB9 card in my laptop? I need to be able to DNC from my laptop because I am using the desktop to run another machine using Mach3. Thank's for the help!!!!
    Feb 2007
    171
    Darbee,
    You may consider the Calmotion USB interface rather than fooling around with updating your laptop and still having to hassle with cables and slow baud rates due to electrical noise and the such. Here is a link to the information on them and once you've had and used one, you'll never look back! They are $599 and in stock at CNCPros.
    CALMOTION USB-FADAL MEMORY INTERFACE
    Good luck!
    Brian
    Jan 2004
    3154
    I have this card.
    1 Port Native ExpressCard RS232 Serial Adapter Card with 16950 UART
    As you can see it is $82 and is native.
    Neil may be interested in the Calmation if he doesn't want one of these.
    Feb 2007
    171
    Just pointing out no need to fuss with RS232 protocol much anymore with the Calmotion interface. Most who try one never go back. Cheers!
    Sep 2009
    181
    Quote Originally Posted by neilthib View Post
    You can try the USB to RS232 adapter here:
    Pro FTDI USB Serial Converter w/ RX & TX LEDs - SerialStuff.com
    That should work...
    Need help with your Fadal? Send me a message or visit www.TheFadalParts.com. We have over 25 years of experience at Fadal and offer FREE TECHNICAL SUPPORT OVER THE PHONE!
  1. Need CNC Communication Software
    By Dualkit in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-31-2017, 11:09 AM
  2. ip/tcp vs. com communication
    By Rylee in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-07-2011, 08:11 PM
  3. USB to RS232 NO Communication?
    By frz400 in forum DNC Problems and Solutions
    Last Post: 10-23-2008, 11:16 PM
  4. Need help with communication.
    By AceikTool in forum EDM Discussion General Topics
    Last Post: 09-30-2008, 07:33 AM
  5. PC<->NC communication
    By loky in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-27-2007, 09:44 AM
