586,126 active members*
3,053 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma LC40 Twin Turret
Results 1 to 8 of 8
    Jul 2010
    Hi all,
    I'm currently figuring out how to use the LC40 in our workshop. I got the program down pat (G13's and G14's where they should be, etc) but i dont know how to run both turrets in the program to complete a finished part. (T1 from A turret comes down, turns, goes home - then T1 from B Turret comes up to drill a hole, etc) unfortunately i cant post the program as of yet but from having a nosey at old programs the old operator used to write theyre full of "P10" and "P11". What are these codes and are they relevant to what i'm trying to do?
    Thanks for your help in advance.
    Brisbanite :drowning:
    Feb 2009
    6028
    P-codes are timing. If you want both turrets together, use the same P number IE G13T0101 X4.Z0P10
    G14T0202X4.Z0P10
    Mar 2009
    1982
    directly relevant. P10 and P11 desrcibes synchronisation of turrets - which is master, wich follows. It describes "balanced cut" conditions also.
    Nov 2010
    How you use synchronisation takes practice to optimise the program, all you can do is study some programs and start by writing simple programs to gain confidence.
    When I worked for Okuma, they did produce a training manual for this type of programming, Contact Ellison Machine Technologies for some advise.
    Maybe they have a copy you could buy.
    Apr 2006
    822
    Welcome to the Zone Brisbanite!
    P codes are, as others have stated, Synchronisation codes.
    As you have already discovered, you can control the order of execution of processes on each turret by way of using the "P" code numbers.
    "P" codes will always be increasing in value (there is an exception to this a per usual!) through out the program, i.e. P20 will always be after P10 otherwise an alarm will occur.
    "P" codes can be of a smaller value than the last one used, only within a shape designation section of the program...
    i.e. between G81/G82 and the matching G80
    This is used to synch turrets when using balanced cutting (two tools machining the same shape, usually the OD) and you need to make sure that both tools are kept synchronised.
    To commence cutting simultaneously between upper and lower turrets you must use the same P code on both turrets.
    P codes can give you a range of alarms and I usually found it best to not bother trying to look for a solution to the alarm by looking at the program first! Check the alarm manual First, this will tell you what problem is actually present, i.e. maybe the problem is different spindle speeds commanded, or maybe different gear ranges commanded... you can spend lots of time looking for the problem if you do not know exactly the cause of a "P" code alarm first!
    I used to program my old LC20 like this:
    For example the order of operations was thus:
    Face
    Drill
    Rough OD / Rough ID
    Finish OD / Finish ID
    Part off and Catch
    End
    Tooling would be setup thus:
    Turret A (G13)
    T5 Rough ID
    T6 Parting tool
    T7 Finish ID
    Turret B (G14)
    T1 Facing tool
    T2 Rough OD
    T3 Finish OD
    T5 Drill
    T6 Parts Catcher (Usually a piece of Nylon of appropriate Diameter and Length to fit down the bore and allow the part to fall onto during machining).
    A sample program for machining a 'Bush' from solid, 100mm long, 120mm OD, 80mm ID
    would be something like this...
    (program listing has been only roughly checked for accuracy, no responsibility taken for any mistakes made! )
    $TEST.MIN%
    G13
    P10 (EXECUTE FIRST)
    M90 (DOOR CLOSE)
    G0 X300 Z800
    G14
    P20 (EXECUTE SECOND)
    G0 X300 Z800
    G50 S3000
    NOEX (FINISH FACE)
    NSTRT X122 Z102 TG=1 OG=1 G97 S636 M3 M8 M63
    G96 G111 S200 (G111=TURRET B USED FOR SURFACE SPEED CONTROL)
    G85 NFF D1.5 F0.2 W0.2
    NFF G82
    G1 Z100 G41
    X0
    G40 I-0.02
    G80
    G0 Z800
    NOEX (DRILL ID)
    NDRIL X0 Z800 G97 S540 TG=5 OG=1 M65 M66
    X0 Z102 TG=5 OG=1
    G74 X0 Z-6 D154 L154 F0.10 E0.17
    G0 Z800
    N1 X300 Z800 TG=2 OG=1 M65 M66 M63 G97 S624
    G13
    NOEX (ROUGH BORE)
    NRID G0 X56 Z102 TG=5 OG=1 G97 S521 M63 P30 (SYNCH WITH B TURRET AT P30)
    G85 NLAPB D5 F0.3 U0.5 W0.1 P35 (SYNCH THE START OF THE ROUGHING CYCLE AT P35)
    NLAPB G81
    G0 X82
    G1 Z100 G41 F0.18
    X80 Z98
    X80 Z-5
    G40 I-0.01
    G80
    G0 X[V6-2]
    Z400
    X82 Z400 TG=7 OG=1 M65 M66
    M1 P38 (SYNCH OPTIONAL STOP)
    G14
    NOEX (ROUGH TURN)
    NROD G0 X400 Z102 TG=2 OG=1 G97 S521 M63 P30 (SYNCH WITH A TURRET AT P30)
    X122
    G85 NLAPT D5 F0.3 U0.5 W0.1 P35 (SYNCH THE START OF THE ROUGHING CYCLE AT P35)
    NLAPT G81
    G0 X118
    G1 Z100 G42 F0.18
    X120 Z98
    X120 Z-3.5
    X122
    G40 I0.01
    G80
    G0 X300
    Z400
    X300 Z800 TG=3 OG=1 M65 M66
    G13
    NOEX (FINISH BORE)
    G0 X82 Z102 TG=7 OG=1 G97 S610 M63 M3 P40 (SYNCH WITH A TURRET AT P40)
    NOEX M8
    NFID G87 NLAPB P45 (SYNCH THE START OF THE ROUGHING CYCLE AT P45)
    G0 G91 X-0.5 (MOVE TOOL 0.5MM CLEAR OF ID)
    G90 Z800 (RAPID CLEAR ON Z)
    G14
    NOEX (FINISH TURN)
    G0 Z102 TG=3 OG=1 G97 S610 M63 M3 P40 (SYNCH WITH A TURRET AT P40)
    NFOD X120 Z102
    G87 NLAPT P45 (SYNCH THE START OF THE ROUGHING CYCLE AT P45)
    G0 Z101
    G87 NFF2
    NFF2 G82
    G1 Z100 G41
    X78
    G40 I-0.02
    G80
    G0 X400 Z101
    X400 Z400
    X400 Z800 TG=6 OG=1 M65 M66 (INDEX TO PARTS CATCHER)
    G13
    NPART G0 X300 Z400 TG=PT OG=1 M65 M66 (PARTING TOOL)
    P5001 (START SYNCHING THE PARTING TOOL MOVEMENTS WITH THE PARTS CATCHER)
    G97 S390 M3 M63 P5002 (SYNCH THE SPINDLE SPEED)
    G0 X500 Z800 P5010
    X500 Z-3.1 TG=6 OG=1 G97 S390 M3 M8 M63 P5020 (SYNCH MOVEMENT TO THE CUT OFF POINT)
    X122
    G96 G110 S150 M61 P5030 (SYNCH CUTTING SPEED WITH OTEHR TURRET)
    G1 X118 F0.1
    G0 X122
    Z-2.1
    G1 X120
    X118 Z-3.1 (CHAMFER PART)
    X78 (CUT OFF PART)
    G0 X122 P5040 (MOVE PARTING TOOL AWAY FIRST)
    X400 Z800 (AND THEN TO HOME POSN)
    X400 Z800 TG=5 OG=0 M65 M66 (INDEX TO ROUGH ID TOOL READY FOR NEXT PART)
    X400 Z800 TG=5 OG=0
    M5 M9 P9999
    G14
    NPC G0 X400 Z800 TG=6 OG=1 M65
    P5001
    G0 X500 Z800 P5010
    X0 Z110 TG=6 OG=1 G97 S390 M3 M63 P5020 (SYNCH MOVEMENT TO FRONT OF PART, PART TOOL TO Z CUT OFF POSN)
    Z0 (MOVE CATCHER INTO 'CATCH' POSITION WITHOUT WAITING FOR ANY SYNCH)
    (LOWER TURRET NOW WAITING IN PLACE WHILE TOP TURRET IS CUTTING OFF PART)
    Z110 P5050 M5 M9 M63 (MOVE PART CATCHER BACK TO FRONT OF PART AFTER MOVING PARTING TOOL CLEAR)
    M01 (OPTIONAL STOP TO KEEP CATCHER IN PLACE AT CHUCK)
    X500 Z800
    G0 X500 Z800
    M5 M9 P9999
    M91 (DOOR OPEN)
    NEND M02
    Hope this helps a little?
    Cheers
    Brian.
    Jul 2010
    Thanks for the replies guys,
    Currently doing another batch of ten (starting this arvo). The Program that i'm posting is the way i have to do the job. I want to do it exactly the way the program is written..... So here it goes:
    Hopefully this helps!
    Jul 2010
    Quote Originally Posted by brisbanite View Post
    ****! dunno what i did wrong then now i cant post or even copy and paste the damn thing. I'm off to bed now so will try again tomorrow afternoon. Sorry.
    Apr 2006
    822
    LOL just have to love the way stuff just disappears sometimes... one moment it is all there... press the submit button and "blink" it is all gone!
    Better luck next time.
  1. Replies: 4
    Last Post: 10-02-2014, 04:58 AM
  2. OKUMA LC40 INDEXING PROBLEM
    By DWARMUS in forum Okuma
    Last Post: 11-19-2012, 04:15 PM
  3. okuma twin turret axis flip?
    By fishy steve in forum Okuma
    Last Post: 11-11-2010, 02:35 PM
  4. How to align turret on LC40 lathe?
    By SRT Mike in forum Okuma
    Last Post: 07-26-2008, 06:19 PM
  5. Anyone know anything about an Okuma LC40?
    By fastturbovet in forum Uncategorised MetalWorking Machines
    Last Post: 11-16-2006, 12:45 PM
