587,030 active members*
3,658 visitors online*
Results 1 to 7 of 7
    Dec 2008
    8
    Cool Okuma LT300MYW sub-part ejector
    Has anyone seen or know about some sort of comfirmation device for the part ejector used in cnc lathes particularly an Okuma LT300 w/P200 control?
    Something that will throw an alarm/slide hold.
    FYI, my first post so excuse any screwups. :wave:
    Mar 2009
    1982
    what's the problem at first?
    Dec 2008
    8
    Occasionlly a part will not be ejected from the sub spindle because of a chip buildup or whatever then the sub (W-axis) will advance to main spindle to grab the next part and there's an undesirable meeting of the two.
    Mar 2009
    1982
    You can make sensor on the bucket. maybe combination of two: one sensor is actuated - just button pressed by some tool (according part program) and timer starts. Timer causes error if no reset from second sensor, dropping part.
    error action - up to you. You can activate slide hold, for instance
    two parts could be damaged, sure. You will get an alarm of W overload, it protects the machine only.
    There is another, simple solution. Use a tool to side touch not ejected part. No chance to keep it in the sub-chuck (unclamped) while pushing a little with the tool.
    The third solution. Sure, you can make confirmation sensor. A pin, pushed by spring towards the part. The pusher must be hollow, you need proper sealing, you need additional electrical input, appropriate software ... bla bla bla ---
    Dec 2008
    8
    Thanks Algirdas, good ideas. I'm going to try taking a tool like the cutoff and using load monitor to sense wheather there's a part there or not. In the mean time work on adding prox switches to the part catcher.
    Mar 2009
    1982
    load monitor will not sense unclamped part. Make the tool path so, that it will not leave the part in the chuck for sure.
    Dec 2008
    8
    Thanks, looks like it will work.
  1. Ejector pin grinding/cut off machine?
    By Chuck Reamer in forum Moldmaking
    Last Post: 12-20-2013, 01:44 PM
  2. Sub-Spindle Ejector for Tsugami NP-20
    By Thrasher in forum CNC Swiss Screw Machines
    Last Post: 06-24-2012, 08:01 PM
  3. Okuma Howa 2sp-30H part #
    By OKUMA Tech in forum Okuma
    Last Post: 11-14-2008, 09:19 PM
  4. Ejector question - electric machines
    By dav612 in forum Moldmaking
    Last Post: 02-15-2008, 09:48 PM
  5. Replies: 25
    Last Post: 04-13-2007, 01:01 PM
