Hey Guys and Gals;
I've just started routing the aztec calendar and am having a bit of a difficulty. My first problem is my material. I'm using the costly but cheaply made birch plywood from Lowes (woes) and it is causing some hate and discontent here in the shop.
My setup is 24" x 24" blank using a 9/16 v-bit set for 100 ipm. I'm getting chipping in the design, and I would love to repair this after the 3+ hour run.
I'm thinkingof trying to fill the pit with (?) epoxy and re-routing the damaged area. My questions is, what is the best material to repair this with??? Ideally it will somewhat match the wood and be machineable. However, I'm up for any suggestions.
Thanks in advance.
Bill
