586,913 active members*
2,982 visitors online*
    Sep 2010
    12
    Multiple part 2.5D milling (with tabs)
    Hi there,
    I was looking into that for quite some time but did not find a solution for importing multiple SC parts into one SW assembly and milling such an assembly from one stock.
    Have tried the obvious: 1. Designing SW part => 2. Generating SC part => 3. Creating assembly => 4. Inserting SW part into assembly => My efforts end just here since I cannot "re-connect" to the SC part.
    If someone could spread some light about the workflow necessary, this would be super appreciated.
    Thanks a lot, Hanns
    PS. The tabs - well that might be a bit to challenging for now...
    Oct 2007
    499
    Hans,
    You don't need to creat an assembly. Program your part as one piece, select all the jobs, right click and select "Transform" This opens a menu where you can repeat your jobs offset in X & Y. Just make sure that your stock model is big enough to accomodate them all for SolidVerify.
    Sep 2010
    12
    multiple 'different' parts
    Hi Bob,
    Thanks, that is clarification and very handy to know! Crazy I haven't seen that before...
    What I am looking for though is to nest multiple different parts into one assembly. I expect no nesting feature, only a simple way to arrange multiple different CAM parts into one stock (or assembly?). To cut it short: Kind of what you would need to prepare for routing the multiple pieces of an "infamous 3d dinosaur puzzle".
    Thanks again. All the best, Hanns
    Sep 2010
    12
    Hi, Just to close this thread: At last I found 'a' solution; to my understanding even quite elegant. Here's what I did for 2.5d routing: Start an assembly with a part the size of your stock. Use this one for coordinates, stock and target definition. Save that assembly. Now insert all parts to be machined from that stock. Generate operations for all parts now. Eventually save all. Solidcam/Solidworks makes a copy of all parts to the folder of the assembly. All changes on these will be forwarded to the assembly. This is a bit of newbiish description. Hope someone will someday find it useful anyhow. It works for me at least. Thanks again, Hanns
  1. BobCAD - leaving tabs in a cutout part
    By pjensen in forum BobCad-Cam
    Last Post: 07-17-2014, 04:23 PM
  2. 2d Tabs on contour to hold part in blank
    By metalworkz in forum Dolphin CAD/CAM
    Last Post: 05-29-2013, 11:22 AM
  3. How to create bridges/tabs for milling
    By jaras in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-04-2010, 07:58 AM
  4. multiple part profiles
    By meathelmet in forum Employment Opportunity
    Last Post: 01-20-2010, 08:01 PM
  5. Machining Multiple of the same part
    By Hellbringer in forum Benchtop Machines
    Last Post: 02-18-2008, 11:21 PM
