We have 4 Agie wire cuts and the screens are getting less bright as they age. Has anyone found replacements, or made them run LCD screens?
There are replacement monitors available, here: Replacement monitors Agie for example but they are quite expensive. I have been trying to replace the CRT on my old AC100 with an standard monitor of some kind but this far without success... The AGIEMATIC C control, wich I have, used a TTL signal with 19,2 KHZ horizontal and 55,7HZ vertical sync.
Hard to find, believe me...
/Rikard
I have just eliminated my CRT problems on Fanucs. I have a LCD Flat screen replacement that slides right in. I bet I can match one for that Agie. And cheaper than the CRT replacement. What is the model of the CRT? How big screen? Is it color or mono?
Later Jim
I'ts 14" colour. I tried one of these:Video Converters - CGA/EGA/YUV to VGA Arcade HD-Converter PCB (GBS-8220) - JAMMABOARDS.COM - JAMMA Coin-Op Arcade Game Parts - CGA/EGA/YUV to VGA Arcade Converter PCB (GBS-8220) but with no luck. Take a look at the attached picture, thos is the best spec I found on AGIE's original monitors.
Thanks for this, I will post any success we have.
Merry Holiday break, what ever it entails, Colin
