586,892 active members*
4,426 visitors online*
Page 1 of 2 12
Results 1 to 20 of 24
    Dec 2008
    319
    NPT Rigid Tap?
    I'm assuming rigid tapping of NPT in aluminum is ok?
    Anything special I need to know?
    This will be done on our TM-2, FYI.
    Tim
    Feb 2008
    183
    No differant than any other tap , but (there's allways a but ain't there) it will depend on how big npt I would think before it would stall out the spindal on a tm-2. Can tap 1/2 npt in aluminum on are ec-500 but it's pushing it
    Just push the button,what's the worst that could happen.
    Jul 2005
    12177
    I have stalled a Super MiniMill trying to tap 3/8" NPT. The way I eventually managed to get some holes tapped was peck tapping going in less than a thread per peck.
    And I held my hand ove r the E stop button just in case it stalled.
    Apr 2003
    1873
    That really surprises me, have done a lot of rigid tapping but no NPT, would not have even crossed my mind that it would be very iffy on a TM.
    What was the rpm?
    What lubricant?
    Ken
    Jul 2005
    12177
    Quote Originally Posted by Ken_Shea View Post
    What was the rpm?
    What lubricant?
    Ken
    1000 rpm and extra rich water mix coolant. The thing with NPT taps is they are cutting on the full length because of the taper, regular taps are only cutting on the leading few, one or two, threads. Hand tapping NPT is hard work especially 1/2" and above.
    Interrupted thread tap will help lighten the load
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    Apr 2003
    1873
    In production one does not have the time to coddle machining processes, but if you did, would a specialized tapping lube be of help, like Tap-Magic for example.
    You mentioned it stalled your machine, what method were you using to hold the tap?
    tap oil is a major help , it cuts down the possibility of thread tearing a lot , but so do the interrupted thread taps I mentioned above , spartap makes an awesome oil
    Apr 2003
    1873
    Just did a little search on interrupted thread taps with NPT, appears to be no down side.
    Apr 2003
    1873
    Just looked,
    Actually have two sizes of that exact thing in 1/8 and 1/4, straight flute but still an interrupted tap, will have to try those and see how it goes.
    I don't recall ever using a straight tap like that , but it should work especially nice on deep holes , I find the pipe taps tend to not pack up as badly with chips and crap , which is most of the cause of spindle load and thread damage
    Nov 2009
    23
    Interupted NPT taps are nice for aluminum and other soft materials, just don't use them on hard materials = snap!
    Someone mentioned 1000RPM - that's way to fast to tap with NPT! Normal speed for Aluminum would be around 100RPM or less if tapping 1/2NPT or bigger.
    Apr 2003
    1873
    Another good option would be single point thread mill, would take a bit more cad work to draw the helix since that is kind of automated in a straight thread but still would eliminate almost all of the issues we have been discussing here.
    Apr 2003
    1873
    Quote Originally Posted by Medm View Post
    Never have tapped anything at 100rpm, thought I was being extra/ultra conservative at 200.
    EDIT:
    Just checked my threading software, 6061-T6 1/2-14 NPT recommended rpm was 455, standard tap, no HP.
    EDIT: again
    Not really sure on that now, was not a NPT tap.
    Nov 2009
    23
    I/we tap at 50RPM in stainless on a daily basis.
    the problem that I find with single point threadmill is that it is slowwww
    100 rpm is slow , I think the slowest that I've ever tapped was about 350 , but that was with a (if I recall correctly) 1 1/8" straight tap X 2" deep in structural steel , gotta love big machines
    Apr 2003
    1873
    Can't speak to SS, never tapped any of that, some SS machines nicely, others do not.
    Apr 2003
    1873
    Quote Originally Posted by dertsap View Post
    100 rpm is slow , I think the slowest that I've ever tapped was about 350 , but that was with a (if I recall correctly) 7/8" straight tap X 2" deep in structural steel , gotta love big machines
    Production would likely not be using single point but multi point.
    Single point just covers a lot of ground with one thread mill.
    they're certainly handy for getting the job done (single flt)
    most of the stuff I do now is small so its been a while since I've had the need of a threadmill , I used to use a lot of large multi point thread mills , both straight and tapered , they are great but the noise can make people pretty jumpy and take time to get used to
    Apr 2003
    1873
    That's a fact, all tools have their own sound and do take getting used to, I have quite a bit of non professional time under my belt and I'm still jumpy.
Page 1 of 2 12
  1. Replies: 24
    Last Post: 05-01-2014, 07:02 AM
  2. Can I rigid tap?
    By sluggo in forum Fanuc
    Last Post: 02-08-2012, 07:24 AM
  3. rigid tap
    By manuel2008 in forum Mastercam
    Last Post: 04-23-2008, 03:10 AM
  4. rigid`ing tm-1 ?
    By pit202 in forum Haas Mills
    Last Post: 04-11-2008, 01:31 PM
  5. rigid tap
    By dcalp in forum FeatureCAM CAD/CAM
    Last Post: 02-20-2008, 11:59 PM
