586,728 active members*
3,325 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Spindle Drive fault 60, A06B-6111-H015
    May 2007
    58
    Spindle Drive fault 60, A06B-6111-H015#H550. I have an issue with a Doosan lathe, it has a Fanuc OI controller, the Message is:
    9110 SPN 1:S-Spindle error (AL-110)
    And the Spindle drive has the 60 alarm, the power supple is showing an "A" state...I am not familiar with this fanuc controller, and our books only show error codes up to 59. I have not seen the 9110 anywhere in the Doosan books, but I am assuming a 9000 series alarm has something to do with the controller....
    Any thoughts to help me out?
    It's not what you cut...It's what you don't cut.
    Jul 2008
    29
    9110 is a communications error between the amp and the module.
    I believe the spindle amp is showing b0 not 60. Check your cables or it could
    be your spindle amp.
  1. 1992 VF2 Alarm 123 spindle Spindle Drive Fault
    By dafowfidy in forum Haas Mills
    Last Post: 05-14-2012, 07:32 PM
  2. Spindle Drive Fault
    By bk1955 in forum Bridgeport / Hardinge Mills
    Last Post: 10-19-2010, 02:24 PM
  3. Replies: 4
    Last Post: 10-15-2010, 07:10 PM
  4. Fanuc A06B 6064 C312 Spindle drive
    By jkford96 in forum Fanuc
    Last Post: 02-21-2007, 04:16 AM
  5. Spindle Drive Fault
    By n5jjr in forum DNC Problems and Solutions
    Last Post: 03-31-2005, 03:26 PM
