586,860 active members*
3,206 visitors online*
IndustryArena Forum > Material Technology > Material Machining Solutions > Drilling hole through axis of aluminum bolt
Hybrid View
    Nov 2010
    I am new to machining. I've done some drilling but not much. I would like to drill a hole through the axis of an aluminum bolt. The bolt is about 5/16" in diameter and 1" long. The hole will be 1/8". Is it feasible to do this with just a hand drill? I can secure the bolt on a work bench.
    Thanks!
    Feb 2007
    664
    do you have a drill press ?
    if so clamp a block of metal on the table with a tap drill of the size thread on your bolt drill a hole
    then tape the hole (don't move the block) then thread the bolt in the hole and drill away
    put some never sieze on the thread if you use an aluminum block
    Nov 2010
    No I don't have a drill press. I don't do a lot of drilling so I've been fine with a hand drill so far.
    Feb 2007
    664
    Quote Originally Posted by ChronoCube View Post
    i have seen some people drill a nice hole with a hand drill , I'm not one of them
    give it a try
    good luck
    Kevin
  1. Drilling Bolt Hole Patterns
    By TURNER in forum G-Code Programing
    Last Post: 09-17-2013, 04:13 AM
  2. deep, small hole drilling in aluminum
    By Fala_Man in forum Material Machining Solutions
    Last Post: 04-12-2013, 07:18 AM
  3. bolt parttern around hole
    By Runner4404spd in forum Solidworks
    Last Post: 02-02-2008, 01:08 AM
  4. bolt hole circle
    By sanddrag in forum Employment Opportunity
    Last Post: 01-23-2007, 01:52 PM
  5. Drilling a hole in the center of a bolt / newby question
    By stickben in forum Mechanical Calculations/Engineering Design
    Last Post: 04-30-2006, 05:07 PM
