586,961 active members*
2,726 visitors online*
Results 1 to 7 of 7
Hybrid View
    May 2007
    4
    Sinumerik 810M MD364* MD368* problem!
    Trying to do a retrofit with Sinumerik 810M (3GE 570.805.9101.04) but I have a problem.
    My encoder has 1000 imp / rev and the pitch of ball screw is 8mm.
    The display shows the path taken 2 mm for full circle.
    >>MD 364 * and 368 * have no effect on measured size.<<
    Please help.
    The label 3GE 570 805 ... What does the 805 ... System 810 not configurable.
    Nov 2010
    can you explain in more detail please.
    May 2007
    4
    My problem is that I can not set up a measurement system to measure the real mechanical movement.
    My encoder has 1000 imp / rev (mounted directly on the ball screw), the pitch of ball screw is 8mm.
    Mech. movement of 8mm (one full circle of ball screw) = 2mm actual value display on NC monitor.
    How do I set parameters to get the right actual value (8mm)?
    >>MD 364 * and 368 * have no effect on measured actual value.<<
    Steva
    Aug 2006
    93
    Quote Originally Posted by steva.vojnovic View Post
    Steva
    first things first ,..in all CNC control system ,..such as Siemens Heidenhain Fanuc ,..before all you must mention the axis is rotary or linear ,..then you must mention that linear axis measuring sytem is rotary encoder or linear scale ,..then mention the pulse per revolation ,..if you dont have the 810M manufacturer document ,..just let me know
    May 2007
    4
    I have experience with the latest numeric control.
    I set the linear axis, I have manual for 810M but,
    MD364* Pulse no. increment for variable weighting (in my case 4000), and MD368* Traverse path for variable increment weighting (in my case 16000) have no any effect on actual value.
    Please help
    Apr 2009
    8
    wrong machine data
    i think you are looking at the wrong md.
    let me get back to work monday and i will look at some of my machines and verify what md you need to be configuring.
    do you have pdf manual for the 810 control?
  1. SINUMERIK 810M - 7024 error
    By rliovic in forum SIEMENS -> Sinumerik 810M/810T
    Last Post: 09-23-2011, 04:20 PM
  2. Sinumerik 810M - error 2087
    By hartan in forum SIEMENS -> Sinumerik 810M/810T
    Last Post: 01-02-2011, 12:09 PM
  3. Sinumerik 810M changing default settings
    By ignace in forum SIEMENS -> GENERAL
    Last Post: 10-07-2010, 05:18 PM
  4. SINUMERIK 810M GA1
    By amo in forum CNC Machine Related Electronics
    Last Post: 11-17-2009, 09:58 AM
  5. Sinumerik 810m ga2 ram module battery question
    By jgriffith66 in forum CNC Machine Related Electronics
    Last Post: 11-26-2007, 08:39 PM
