Does anyone know the correct hookup for the 3 phase power to the terminals inside the cabinet? One fuse has blown twice in 3 days. I need to know which terminal the 240V leg of the 3 phase hooks to?
As per Mori instalation manual, all legs must be 5% of each other or better. If all legs are good, please specify what fuses are blowing.
I have 2 Mori TV -30's. I was told to put it on L2, the middle leg on both machines. That is what they call the wild leg. You just have to make sure that leg doesn't run straight to the control and your fine. It should run to a transformer first.
