I am running 2 (6amp) & 1 (3.75V 2amp) stepper motors, With 68VDC. The 6amp's seem to run fine, but after awhile they get hot from sitting or until i do alot of rapid moves. But the small z motor gets super hot to touch, when its just sitting there, in about 10mins?
Also i need help setting up Turbcnc, I've set it up with 200steps/rev, 5.0625 TPI, 10Microstep, 1:1 Gear. & it came to a scale of 0.00009876, but it wasn't make an inch, so i adjusted the scale to 0.00009816, It now makes an exact inche when told to go an inch. But my question is why did i have to adjust it off like that?
Also what is good to set the Hz's at? for the motors ( 2 @ 1200Oz.in / 1 @ 270 Oz.in.)
-Will
