586,307 active members*
3,016 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Problem When i try to bring up T2!
    Nov 2010
    Hi, iam new here and was wondering if i could get some help. I changed the timming belt on our Excel PMC-5T18. Every thing works ok, but now when i got to bring up tool 2, (T2M6: ) I get an error message. OPERATOR MESSAGE NO. 2050, T code error due to:
    1)T code not applicable, or
    2)Duplication of tool number in tool Data Management. Address D100 to D124, or
    3)T code not available for Big Tool set.
    Is there any way some one could help me? Thank you.
    Dalton Greer
    JACO Machine Works
    Feb 2007
    498
    when you say changed timing belt,you mean the spindle belt?if so you need to orient the encoder right and im not sure how to do that,i watched a tech do it for my haas and still dont know how,check your manual
    Mar 2008
    150
    I suppose that Dalton means that this only happens on T2, and not on any other tool and isn't that strange if that should be the encoder!?
    Anyhow, to adjust the spindle orientation in my Fanuc MXP-100i at work it's the value in par.4077, but you need to check wich par for your control in your manual!
    If it has with "Big Tool Set" to do, you do that settings in DGN, but again you must check you're manual.
    Kitamura Mycenter 1 -83 with Fanuc 3M-C and Mycenter 1B -85 with 10M control.
    Yes, they are old..... but i still like them!
    Nov 2010
    Thank you, but where would the DGN settings be? Iam looking in my Fanuc Parameters manual and came not find anything.
  1. Bring table to center
    By bowmaster in forum Haas Mills
    Last Post: 07-26-2010, 04:17 AM
  2. Moving to Oz, just how much of the shop to bring....
    By janders57 in forum Australia, New Zealand Club House
    Last Post: 07-06-2009, 10:30 AM
  3. Backlash...bring the flames.
    By JeepJake in forum Charter Oak Automation Support Forum
    Last Post: 02-07-2009, 06:06 PM
  4. bring you fortune
    By lianglish in forum CNC Swiss Screw Machines
    Last Post: 08-22-2008, 08:21 AM
  5. How bring together Fadal 32 MP and PC
    By puberter in forum Fadal
    Last Post: 01-22-2005, 07:59 PM
