Originally Posted by
Stebedeff
Hello to all,
I' am having a small problem with my control.
First of all I have 2 mills both using Fanuc Om.
I set up the drip feeding on both and they both work just fine.
Sending/Recieving programs no trouble at all.
The only problem I have with 1 of the mills is that after drip feeding and the part/program is finished, the transfer status window which apears when sending/recieving data is not saying "transfer done". So the status windows stays at 99% even though M30 already was read. It just hangs and do nothing.
It's then not possible to send new program because it the port is still in use.
So I have to richt click and close window and pass through all the failure messages untill all is closed and ready to send again.
I'am having this trouble with only 1 machine while the other works just fine.
Is this mill not sending the X-on/X-off ? With drip feeding it's not buffering neither, just reads line after line.
I have no clue at all. Any help would be appriciated.
thanks
