It was a hard decision to choose between the Novakon NM-200 and the Tormach PCNC 1100. This was primarily due to Tormach’s superior online documentation and large CNCzone following versus lack of online documentation on the Novakon web site as well as negative publicity from idesign and others.
I am happy to say that my anxiety, fears and sleepless nights thinking about which CNC machine to buy were totally unwarranted. The Novakon NM-200 Pro Series 2 CNC mill is awesome! Novakon provided NM-200 setup, user and MPG manuals, and numerous other written or PDF files documenting the setup and use of CAD, CAM and MACH3 software, computer/computer boards, and other miscellaneous items. The provided documentation along with additional information available on numerous web sites is more than enough for a novice to learn and do CNC milling.
Both the Tormach PCNC 1100 and Novakon NM-200 CNC mills are the best machines in their price range. However, I chose the NM-200 for the following reasons:
Khai Uong (Novakon Director of Sales) – His pre-sale support, fast day, nights and week ends e-mail responses to my questions were extraordinary and way beyond what one would expect.
Larger table size (40’ x 12”)
Superior X and Y travel (24” and 15”)
Fifty percent larger XYZ machining work space envelope
The availability of 5th and 6th axis’s
Three HP spindle motor
No belts change required when adjusting spindle RPMs from the lowest to the highest speeds available (The Novakon NM-200 does not use pulleys and belts)
Computer built into the modular controller cabinet (the same as higher end CNC machines)
Availability of Visual Mill CAM package (Works well with Alibre and is much simpler for me to use than SprutCAM)
Larger stepper motors
The availability of a Stepper Feedback Detection System (This system provides instance feedback if the CNC mill were to loose steps, thus preventing damage to the machine or the part being machined)
In the end, Novakon won my order by being able to provide a better package for less money.
I was able to assemble and use the NM-200 CNC mill and stand within a 24-hour period. It was a turnkey operation as my NM-200 came with the computer built into the controller panel. All stepper motors were already installed.
