586,133 active members*
3,950 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Help !! Stepper only turns in one direction?
    Sep 2010
    Please Help
    I am switching over from MicroKinetics software, opti board and opti driver. Am setting up tubocnc, slo-syn ss2000 md4 drivers and same steppers (which worked fine with the opti stuff) –Vexta m06 008 (12v .68a).
    The problem is the motor will only turn in one direction. Using pin 2 step and 3 direction(set high). When I jog the motor, It turns one way no matter with way I jog. If I pull direction pin wire it turns in the other direction. I tried a 10k dropdown res. No change. Hope someone can help me.
    Thanks in advance
    Jan 2006
    738
    On that driver, there is an "opto" supply (nominaly 5V) that supplies the anode end of the LED's in the opto isolators. The cathode ends of the LED's in the opto isolators are connected to the inputs. A logic low at the input turns the opto on. A logic high or an open circuit at an input will turn the opto off. Take a look at the circuits on page 17 of the instulation manual....
    http://www.bibus.hu/fileadmin/produc...000md4m_en.pdf
    It may be that your pin 3 direction output is not able to go all the way to a high level of 4V.
    Steve
    May 2005
    1397
    Are you absolutely certain that pin 3 on the parallel port (not data pin 3) is connected to the direction signal on your stepper driver? I've made that mistake (recently) and it took me a while to figure it out. LOL...
    Also, keep in mind that pin 2 and 3 are not data 2 and 3 since the strobe pin is on pin 1, data pin 0 (the first data pin) is on pin 2 of the connector.
    Parallel Port Signal Detail
  1. 4th axis turns to many turns
    By cob in forum Mastercam
    Last Post: 02-16-2009, 07:19 PM
  2. Stepper motor only turns one way
    By henryblowery in forum Stepper Motors / Drives
    Last Post: 12-21-2008, 05:01 AM
  3. Stepper turns only one direction
    By jhowelb in forum Stepper Motors / Drives
    Last Post: 10-04-2007, 01:52 AM
  4. Stepper only going in one direction?
    By ScuD in forum Stepper Motors / Drives
    Last Post: 12-09-2005, 12:28 PM
  5. Stepper rough 1 direction
    By randyf1965 in forum CNC Machine Related Electronics
    Last Post: 05-25-2005, 08:17 PM
