587,012 active members*
3,574 visitors online*
    Oct 2010
    21
    Need (hopefully simple)G code Help
    My g code writing is next to none.......
    Here is my problem
    I am doing a job that requires drilling a series of holes on a part on all 4 sides.
    so the part is mounted on the a axis. drill holes turn to 90 degrees drill holes turn to 180 drill, turn to 270 drill, then turn to 360. What g code command can I give the stupid processor, so it doesnt have to turn the indexer all the way back around to zero each time?
    Nov 2009
    23
    Info needed
    What machine/controller/manufacturer are you writing the code for. This information should always be included with your question. That way I/we can answer appropriately.
    Oct 2010
    21
    Need help g code
    Sorry O forgot to include that. Mill is a syil x3 Software is Mach 3
  1. simple G code translation please!
    By Stewey in forum G-Code Programing
    Last Post: 10-19-2010, 10:04 AM
  2. Simple G-code to make, please help ):
    By waxmund in forum G-Code Programing
    Last Post: 10-07-2010, 01:29 PM
  3. I need a very very simple g-code file please.
    By Ranscon in forum G-Code Programing
    Last Post: 09-03-2009, 12:13 AM
  4. Need help with simple G code
    By Step by Step in forum Coding
    Last Post: 10-25-2008, 02:49 AM
  5. Simple G-Code program?
    By N4NV in forum G-Code Programing
    Last Post: 03-25-2006, 01:35 AM
