586,477 active members*
2,302 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal VMC15XT Servo amplifier fault on all axis
    Nov 2010
    8
    This machine is 1997 Fadal VMC15XT with 88HS control
    When doing CS after powerup i get
    X axis servo amplifier fault
    Y axis servo amplifier fault
    Z axis servo amplifier fault
    Error number is #18
    Pressing JOG to reset e-stop results Amplifier fault on axis that is selected with knob.
    What i have done so far:
    - Measured all fuses and breakers -> none of them was blown
    - Measured +12/+5/-5V power supply -> voltages are good
    - Reseated every card/connector/relay
    What would be next thing to try?
    900
    Kizmo--
    Check the voltage at the blue cap. It should read 125 to 165 volts DC. If it does not then there may be an issue with the blue cap or the amp chassis.
    Neal
    Nov 2010
    8
    There is about 11.70VDC over blue cap.
    120VAC can be found from the other side of large solid state relay next to bridge rectifier which should provide this +170V
    900
    If you have 120vac into the bridge rectifier but low DC voltage on the output side then you have found your issue.
    Neal
    53
    After first power on, look at the amp boards and see if there are any lights. (you may have to have someone else push the green button while monitoring the amp boards.)
    If amps light then go out after 3-5 seconds, you may have an issue with the resolver circuit.
    If all amps stay on until you try to CS the machine, I would instead try jogging one axis at a time BEFORE trying to CS.
    While thinking about it, did you make sure the E-stop button is released? Sometimes the most simple solutions are overlooked.
    -Scott
  1. fadal servo amplifier fault
    By bala955 in forum Fadal
    Last Post: 06-17-2015, 12:00 AM
  2. Fanuc Servo Amplifier Fault
    By turbo jim in forum Uncategorised MetalWorking Machines
    Last Post: 05-16-2011, 08:30 AM
  3. WOW X, Y, Z Servo amplifier fault!!!
    By carbidecraters in forum Fadal
    Last Post: 03-19-2009, 11:05 PM
  4. "amplifier fault on axis" on fadal VMC 15
    By siquedude in forum DNC Problems and Solutions
    Last Post: 11-21-2007, 12:11 AM
  5. Z axis Amplifier Fault on Fadal 4020
    By Fudd in forum Fadal
    Last Post: 08-29-2006, 11:01 PM
