For you Taig guys... I have one. (Gecko G540 not Taig control) Its a decent little machine for the price, but requires constant adjustment to keep it running with decent amounts of backlash. I would be torn between it and the Max NC except the MaxNC uses their own driver and lighter motors than I like. (I retrofit one to Mach / Gecko control w/ heavier motors).
I have had my Taig for over two years, and I have put hundreds and hundreds of hours on it. (Probably thosuands) Sometimes running as much as 30 hours continuous on a single job at speeds upto 50 IPM for rapids. It has 20 IPM V thread leads screw.
I have had it almost completely apart several times, and the biggest problem it has with the nuts besides needing to be adjusted about every 10-20 hours of run time is the way they are mounted. The have a stub that just seems to press into the machine. ICK!!! On my Z axis it actually started to wear out and was contributing backlash at that point. Double ICK!!! I took it apart and used a shim and pressed it back together to reduce that problem point. The bearings on the lead screw shafts need to be periodically snugged up. Usually about every 100 hours, although it may be more often. I didn't realize that was a problem point right away. Its easy to tell. Adjust the lead nuts, loosen the gibs and grab the motor to push in and out on the lead screw. If you can feel movement its due for another 1/32 to 1/16 of a turn of tightening. Don't over tighten as you will just crush the bearings and it will make a nice grinding noise as it moves.
Anyway... As fas as acetal...
One poster in this thread "as long as you don't exceed 500 RPM." 500 RPM is awfully slow. To slow for this machine IMO. I have not independently verified their number, but here is what I get.
500 RPM / 20 TPI = 25 IPM. 25 IPM is not bad for cutting, but I have my machine set at 50 for rapids on X & Y, and I sometimes cut as fast as 30 or 40 for some stuff. I can run 60 using stepper motors, but that's right at the edge of reliability for control position.
Please note: 50 is a little enthusiastic for the Z axis on my machine. The Z axis is just not a very good design compared to the X & Y and it has the potential for binding. If you are using the stock motor and spindle even 30 is a little optimistic with all that weight. I was upset when I discovered the Z assembly ways were not straight, but Taig told me .01 was acceptable tolerance for them. Designing my own Z-axis for the machine is on my short list. I'm currently running my own mounting bracket and a Bosch router as a spindle. This gives me more power and a lot less weight on that axis. (not good for steel, but awesome for aluminum)
Anyway if 500 RPM is a realistic do not exceed RPM for a 1/2" V groove lead screw then acetal may not be a good choice for this machine. If looking at acetal a change to a 10 TPI acme screw might be in order. That would put my reliable max speed (for steppers) right at the the max RPM reccomended by the OP. Actually repeatability would improve due to the slower RPM of the stepeprs and reduction of lost steps. Obviously with lower pitch you could run faster, but then you would exceed the RPM target suggested.
Yes I do realize this original thread is over a month old.
Just thinking out loud.
Bob La Londe
http://www.YumaBassMan.com
