Originally Posted by
2Bits
Or should I just replace my transformer, but if I did, I'm thinking I should switch to a Toroidal type, but again, not sure which one.
Would like some thoughts on this.
Mark
Contact Antek see what he has to offer, he sells on ebay all the time, even if you get something like this ebay 250720244597 you could easily modify for the correct voltage.
The secret to the burn out problem is to fuse the primary correctly, if this is done using the right size fuse you should never burn a transformer out.
Al.
