586,655 active members*
2,343 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > FS: Milltronics Partner I
    Jan 2008
    16
    MILLTRONICS PARTNER I
    Machine is not in running condition at this time but has cut parts for us just before we bought it. Need to have X an Y motors rebuilt.
    Spindal Bearings are new with around 20 hrs sense install.
    Moving our shop into a smaller space so we are going to have to scale down.
    Asking $5,000.00 or best offer.
    Call 512-528-1083 for more info.
    Attached Thumbnails Attached Thumbnails 100_4162.jpg   100_4163.jpg   100_4164.jpg
    Mar 2010
    16
    That looks like a Partner I (one) not a Partner IV (four)
    Correct me if I'm wrong
    Jan 2008
    16
    Yep this one is a Partner I (one)
    We had a Partner IV (four) but have sold it already.
    Thanks for look'n out.
    Ronald Self
    Apr 2003
    637
    We have one similar but newer (1995) with a Centurion V controller that keeps chugging along. It would help to state what controller it has, the travels, RPM, HP, year built, # of tool change pockets, where it’s located, etc.
    Sep 2006
    18
    Location
    Where is this machine located?
    Jul 2010
    548
    Look on the right side of the colum for the data plate, here you will find the serial # and the mfg date, also look at the bottom of the control inside the cabinet for the control serial #. Suppling this info will help you sell the machine.
    A control with a "-b" and later is a very "updateable" control. previous controls (no dash or a -A) are not upgradable and would need to have a C6 or C7 control installed if they go down for almost any reason.
    A competent motor repair shop can rebuild the motors as long as the magnets and armature are OK, If not, new motors are about $1200.
    When moving the machine it is best to remove the control from the electrical cabint and the front panel /CRT assembly from the front of the machine and pakage them sucurly. The CRT does not travel well.
  1. Milltronics, Partner IV 4
    By Brian FRF in forum Milltronics
    Last Post: 09-11-2021, 05:53 PM
  2. Milltronics partner 10
    By tasj in forum CNC Machining Centers
    Last Post: 03-23-2010, 06:12 PM
  3. Milltronics Partner
    By MSGMachine in forum Viper Servo drives
    Last Post: 06-03-2009, 02:22 AM
  4. milltronics Partner 1
    By Bada Bing in forum Milltronics
    Last Post: 01-26-2009, 06:54 AM
  5. Milltronics Partner IV
    By Ben Colby in forum Milltronics
    Last Post: 03-27-2006, 11:53 PM
