Faster and cheaper to make them yourself. I just made some from 1/4" CRS flat plate.
I was thinking the same thing. 1/4 20. what material did you use?
1/4" thick Cold Rolled Steel that I got at Lowe's. I drilled & tapped them to use the same studs from the clamping kit I got for my X2. Check your rotary table slots for the thickness to get.
Little Machine Shop has several sizes, these are the smallest (6mm) for a 4 inch rotary table.
LittleMachineShop.com - T-Slot Nuts (6 mm) and Clamping Bars
They have more, look at Chris' tips for part #'s for other sizes.
Hoss
