If I have Soft Limits turned off and hit a limit switch it triggers an E-Stop,
as it should. Using manual over ride I can jog off the switch but as soon as the
axis moves a fraction of an inch and the limit switch closes, it triggers
another E-stop. I then have to hit Reset again, and then can move away as normal. Is this double limit switch triggering of an E-Stop normal? Or is there a setting I've missed?
