Does anybody have experience with the servos from DMM-Tech? Why do we not see more of them used around the forums?
Thank you
Thank you
been selling/applying servos since 1975. thought I knew most the brands. never heard of this one. added: went to dmm-tech.com site and looked around. looks like decent stuff.
A few router builders are starting to use them.
I think that if they had a better website, with more info, they might sell a lot more.
AustinT
The Dmm system is great,I have been doing demos, with there system for customers
for some time now, there are some builds on the zone using there system
Here are 2 builds you can look at, The first one Rod has done some videos
http://www.cnczone.com/forums/diy-cn...nc_router.html
http://www.cnczone.com/forums/cnc_wo...r_project.html
Mactec54
ger21
The web site is getting more imformation all the time, is it flashy, no it is not, but everything you need to get a system running is there, the system is so simple to set up & run you only need to buy the kit
Mactec54
Oh I am glad i found someone who uses the DMM- Servos and here is why. I have a 220 watt servo and drive that I purchased setting next to me on the table. I have been working on it for about 8 hours and I cannot get the motor to make a single move. I am using the GUI for tuning and testing the motor . I have the computer connected to the breakout board with the USB cable. The breakout board is connected on the x axis to Jp3 of the servo drive. Correct voltage is verified and the motor is locked in one position. I have copied the folder specified by DMM to the computer and launched the DMMdrive . The drivers are also installed. The problem is I cannot find the com ports listed under the device manager. I have tried every com port setting on the dmm software and com 3 is the only one that does not crash. It acts like it is reading and writing to the EEProm but when I enter the program again and read the values it is clear the EEPROM is not changed. I believe it comes down to not being able to find the com ports menu under the device manager. Do you have any suggestions?
Thank you
AustinT
I will try & get you through it, You should not of changed anything,as they are ready to run when you get them, the tuning software is not really needed, you just need to connected to Mach 3, to get your motor running, PM me you phone number & I will call you tomorrow
Mactec54
Thank you Pm sent. At this point I am not sure if I have changed anything or not. When I try to read the drive all of the parameters come back as 1 . Why is it that the servos do not need to be tuned for each application? I always thought servos needed alot of attention up front to get all of the parameters correct
Thank you
I just retrofitted a Charmilles hole popper with DMM's 'high torque' servos. This was essentially a hand wheel replacement, but the machine was quite heavy. I had no problems with DMM and they responded to all my concerns. English can be a problem when speaking on the phone but their written communication is good. We used MACH3 to control the system.
My experience with DMM has also been absolutely great! I made the mistake and thought the usb to breakout cable was also used for programming. I spoke with mactec54 on the phone tonight and he is extremely knowledgeable. He found my mistake in a hurry!
Thank you mactec54!
AustinT
You will need a driver/software for your USB to Serial adapter installed on your computer, This driver/software comes with the USB to Serial cable/adapter when you buy them
Mactec54
Mactec,
Is there any plan DMM to make a bigger motor? 750 or 1kw. Thanks.
Mactec54
I am seriously thinking of upgrading from my steppers to the DMM servo system do you have to use the DMM breakout board or can you connect to your existing one?
Andy
audioandy1762
If you buy the kit for your machine, it would be best to use the breakout board, as everything is ready to plug in, board to drive Etc, but if you are good at wiring you could use other breakout boards software Etc, it could also be more trouble than it is worth
Mactec54
Hi Mactec
The reason I asked is that I have a smooth stepper and have just ordered a PMDX126 board. I am not too bad at wiring and ok with software so should not be too much of a challange (I hope)
Andy
audioandy1762
Hi Andy
The only other thing I see that you will have to have, is the power supply filtering & fuse protection, which is on the DMM board, the 48V dc goes through, the on board filter/fuse (20A) before the 48Vdc goes into the drives, So if you have a filter & fuse before the power goes into the drives, that will do the same, Then everything should be good
Mactec54
Hi Mactec,
That is peak power 900 watt, what I ask is continuous power?
Thanks Mactec
Almost ready to put the order in : )
asuratman
Hi asuratman
The continous power is 500watt @ 48V
Mactec54
