586,546 active members*
3,251 visitors online*
Page 1 of 7 123
Results 1 to 20 of 139
    Upgrading another WidgitMaster router
    I've been using this router for over two months now, and I have noticed a weakness or design flaw in the lower y-axis slides! I had made the entire router using IKO LWL12B linear rails, and its obvious now that 12mm is not strong enough for the X & Z-axis weight!
    My solution is to remake the lower section and use THK HSR25CR linear slides. These 25mm slides are designed to take force in all directions, and have a nice grease fitting to lubricate them!
    Attached Thumbnails Attached Thumbnails 100_0933.JPG   100_0934.jpg   100_0935.JPG   100_0936.jpg
    After spending a few days in CAD, I came up with a simple solution. Then I placed an order for materials, and choose a 6"x6" aluminum angle with 3/4" wall thickness. This is much more economical than hogging out a large rectangular block of 6061!
    The front & rear plates will be made from ALCAST-5, which is the Canadian equivalent of MIC-6 jig plate! The Canadian plate is much nicer material to work with, as it is not a chalky or powdery as MIC-6! It works much like 6061!
    Attached Thumbnails Attached Thumbnails 100_0938.JPG   100_0939.JPG   100_0940.JPG   100_0941.JPG
    Next I made a simple layout of the leg lengths on the aluminum angle, by adding .300" to each dimension. Then I pushed them through the vertical band saw, using lots of wax to keep it cutting smoothly.
    With all the excess material removed, I now need to setup the mill for facing the outer surfaces to get an accurate 90 deg. corner!
    By using two little angle plates, I dialed them in so they are parallel to the table's travel. Then I mounted my BIG Chinese 5" dia carbide face mill, I have found it works better if I take 3 of 6 inserts out!
    Attached Thumbnails Attached Thumbnails 100_0942.JPG   100_0943.JPG   100_0944.JPG   100_0945.JPG
    With all the outer surfaces milled flat and 90 deg., its time to mill the length of the long leg.
    So I placed the angle flat on the table, with the short leg against the cast iron angles. Using a 1/2" end mill, I milled the length to print size, then I used a large 2-flute end mill with a .1 radius on the points to mill the step on the inside surface of each part.
    That's enough for one day, as my hands hurt too much to continue!
    Widgit
    Attached Thumbnails Attached Thumbnails 100_0947.JPG   100_0948.JPG   100_0949.JPG   100_0951.JPG
    This morning I finished milling the short leg on both parts, and decided to mill the two plates using the current mill's setup!
    That went quick, but I was unable to mill the slots on the inside of the short leg to hold the linear rails. That needs to be done in a different setup!
    Attached Thumbnails Attached Thumbnails 100_0957.JPG   100_0958.JPG   100_0959.JPG   100_0960.JPG
    Now its time for the fun stuff!
    In order to mill the ends of the rail supports, I need to rotate the mill's turret and extend the ram! So I placed my 6x9x12 angle plate on the mill's table, and clamped it slightly. Then I mounted my long side plate to the angel plate, and clamped the rail support in the corner.
    This gives me a rough idea of how much travel I need, and where to position the spindle.
    Next I tightened all the bolts on the mill's turret and ram, and removed the cast iron angle plate. Because the table is extended and the turret is rotated, the mill's head needs to be trammed in it's new position. So I used an indicator holder in the spindle and a 1-2-3 block.
    The indicator must be perpendicular to the ram, not the mill's table!
    Next I repositioned the cast iron angle plate, and dialed it's face parallel to the mills table. Now I can use a 3" face mill to cut the entire end surface in one pass. So I milled one end of each part.
    Attached Thumbnails Attached Thumbnails 100_0961.jpg   100_0962.jpg   100_0963.jpg   100_0964.JPG
    With one end finished, I used my big height gage to set my little height gage while it was on top of two 4" cubes! This is the only way I can reach something 18.8007" tall with a 12" height gage!
    With the scribe height set, I marked the unfinished end of both parts. There is over an inch of extra metal, so I will band saw the bulk off and finish the parts in the mill.
    Thats enough for today!
    Attached Thumbnails Attached Thumbnails 100_0970.jpg   100_0971.jpg   100_0972.jpg   100_0973.JPG
    Apr 2007
    8082
    Great sequence of instructional photos, as always, from the great WigitMaster!
    But tell me Wigit, is that pair of pipe wrenches on the pegboard precision made and calibrated by Brown and Sharpe? Got lots of chuckles seeing those hanging there.
    Edit: Oops! there's just one pipe wrench. The other one looks like bolt cutters. Even funnier.
    CarveOne
    CarveOne
    LOL!!
    Thanks Carv'e!
    Yea, they were my Dad's, and I must admit they don't get much use!
    Widgit
    This morning I drilled, tapped & reamed all the end holes. This didn't take long, as the mill was nicely setup for milling the ends!
    With all the end work done, I can tear down the setup and put the mill back to normal position!
    After tramming the head again, I cleaned off my vises and put them on the mill table. Then I looked around for the long dual vise soft jaw set, they were scattered everywhere!
    With the vises floating loose on the table, I attached the long jaw to both vises. Then the two shorter ones. Next I closed the vises on a ground steel plate to align a preexisting milled step in the jaws. Then I moved the mill table to the center of travel in the long direction, and positioned both vises so the spindle was in the middle of the long jaw.
    Next I loosely bolted the vises to the table, and tightened the furthest nut on the left. With a dial indicator, I trammed the back jaw within a few thousandths, and locked all the mounting screws tight!
    Using a round steel bar, I tightened both vises and milled the step in the back jaw. Then the front jaws.
    Now the vises are ready to hold parts!
    Attached Thumbnails Attached Thumbnails 100_0976.jpg   100_0977.JPG   100_0978.JPG   100_0979.JPG
    Before I can start working on the parts, I need to set the DRO to zero on the back jaw!
    Next, I used a long 3/4" 4-flute end mill to make the slot for the linear rails. This did not take long, so I started drilling the holes for the M6 threads. After tapping them, I drilled and countersunk the three holes for mounting the router to it's table.
    A good day's work, and the first two parts are finished!
    Attached Thumbnails Attached Thumbnails 100_0981.JPG   100_0982.JPG   100_0983.JPG   100_0984.JPG
    Apr 2004
    90
    You will probably never know how many of us wish we could do what you do every day, and do it as well as you!
    Brian
    Thanks for the kind words Brian!
    Widgit
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
    Jul 2007
    1602
    What drawbar said... It's great to see you posting from the shop again.
    bob
    Thanks Bob!
    This was a difficult router to build, as the Arthritis in my hands and knees makes standing and working painful.
    But I'm addicted, and just cant sit still!
    This machine has cast acrylic wire track mounting blocks, unfortunately I did not take allot of photos during its creation
    Widgit
    This morning I milled the two plates to length, and started drilling holes! All the dowel pin holes in the corners are critical, as it sets the flatness, and squareness of the whole router! So I carefully spot drilled one screw hole, drilled it small, and followed it with a reamer. After measuring it, I made correction moves on the mill. When satisfied with the location, I moved over to the dowel pin holes.
    Next I put a 1/4" reamed hole accurately on location for the ball screw bearing locations. This way I can dial in the hole and enlarge it later.
    So far I have all the lower mounting holes drilled c-bored & reamed, and the holes for the stiffener rails located just under the ball screw. The motor mounting holes have also been drilled & tapped to fit a NEMA23 stepper.
    Because I plan on making a sloped front control panel, with several buttons and an additional e-stop, I will be putting a 1" OD aluminum conduit to connect through the front & rear plates. This tube will also have small holes with rubber grommets so I can connect the two y-axis limit switches.
    I have been looking all over the place for a Green START, Red STOP, anad Yellow PAUSE buttons! Finally I found them at GRANGER.com. Also, I have several small buttons for jogging each axis. Along with a HOME button.
    Now, according to my research, I have 15 OEM-TRIGGER's which will require a 2nd LPT port. Then I can assign each switch & button to a function on the MACH3 screen.
    Attached Thumbnails Attached Thumbnails 100_0988.JPG   100_0989.JPG   100_0990.JPG   100_0991.JPG
    Oh yeah, I forgot to mention that I had made a nice little 4th-axis for this machine!
    It uses standard tapered roller bearings, a corrugated belt & pulleys, and has an 85 oz/1n NEMA23 stepper!
    Widgit
    Attached Thumbnails Attached Thumbnails 100_0996.JPG   100_0997.JPG   100_0998.JPG   100_0999.JPG
    Apr 2007
    8082
    Well, wonders never cease! That one's really nice Wigit.
    CarveOne
    CarveOne
    Aug 2004
    2849
    Eric, great looking work!
    Is the collar on your 4th axis threaded....just wondering how you are preloading the Timken bearings?
    I'm at the point where my Jet JMD-18 is just too limited. Is your mill a Birmingham 10x54? I have been looking at the Enco 10x54 variable speed mills, but don't know anything about how good they are.
    Paul
Page 1 of 7 123
  1. Replies: 1804
    Last Post: 01-02-2024, 05:47 PM
  2. Widgitmaster Wide-Router
    By Jay C in forum Commercial CNC Wood Routers
    Last Post: 12-12-2010, 06:05 AM
  3. Thinwater builds the Widgitmaster Midi Router
    By Thinwater in forum CNC Wood Router Project Log
    Last Post: 11-26-2010, 09:21 PM
  4. WidgitMaster Midi router on ebay
    By rrrevels in forum CNC Wood Router Project Log
    Last Post: 07-30-2010, 01:08 AM
