586,395 active members*
3,028 visitors online*
    Mar 2004
    1543
    AMC servo fault
    I just bought an AMC B30A40 drive off ebay.
    Servo Drives by ADVANCED Motion Controls
    I connected DC+ to the hi voltage power and ground to ground. No other connections. When powered, the amp comes up in servo fault (red light)
    How do i clear the fault? Is the drive bad?
    I do this step all the time with the brushed amps and a good drive comes up green. Then I put a dc servo on (no encoder) and go to test offset to see if it will run the motor. I read you can set this amp to run a brush motor by changing the phase dip switch. So, I plan to use this on a brush servo and do my normal check out.
    Karl
    Jul 2003
    1754
    If you want to test it without hooking a servo up - or a brushed servo up you need to set the dip switches correctly for brushed. If it doesn't see the hal sensors it isn't going to give you a green light (or the hal sensors are not hooked up correctly).
    amc's site seems to be down for me - but this
    http://www.a-m-c.com/download/support/an-007.pdf
    explains how to run a brushless drive with a brushed motor. IIRC you need to switch the phasing swith to off (60deg instead of 120deg)
    24223
    Quote Originally Posted by samco View Post
    Correct, if using a BLDC the Hall sequence has to be correct also, set for 60° for brushed servo using U & V outputs.
    Also the enable has to be set on, there is an internal jumper that will change the logic for on/off designation (active high,or active low).
    Al.
  1. fadal servo amplifier fault
    By bala955 in forum Fadal
    Last Post: 06-17-2015, 12:00 AM
  2. WOW X, Y, Z Servo amplifier fault!!!
    By carbidecraters in forum Fadal
    Last Post: 03-19-2009, 11:05 PM
  3. Z Servo Drive Fault
    By Jaff in forum Bridgeport / Hardinge Mills
    Last Post: 09-09-2008, 08:24 AM
  4. Rejected part because of Servo fault?No more!
    By kolokithas in forum DeskCNC Controller Board
    Last Post: 02-20-2008, 05:53 AM
  5. Servo fault at pgm stop
    By pommac in forum Fanuc
    Last Post: 05-25-2007, 12:58 PM
