586,395 active members*
2,859 visitors online*
    Dec 2006
    310
    Need Help - Sinumerik 840D system
    Dear All,
    In oerlikon gear cutting machine, cutter spindle is A axis
    Error 25000 A axis active encoder fault appears soon after switching on the system
    We checked following :
    a) Cable continuity from Motor upto 611 control card - found ok in Digital multimeter in Resistance Mode
    Checked continuity between connector on junction box over Motor and cable plugged on encoder found OK
    b) Interchanged control card from other axis (Siemens Part number is same for both the control cards)
    c) Replaced Motor encoder with New one
    d) Old NC archieve loaded to ensure nothing wrong with parameters but same alaram
    Kindly advice what else could be the reason
    Best Regards,
    M. Rishikesh
    53
    Bad encoder on motor.
    Feb 2009
    60
    encoder or encoder cable because this fault start by hardware problem
    Aug 2006
    93
    dear sir
    i thinks based on my experience you should check , the counting direction for A axis in NC machine parameter , in 840 D all axis mention by direction to use , you should check it before all .
    Nov 2010
    have the active encoder checked, there may be an additional encoder on the axis and not using the motor encoder.
    Could be a Heidenhain ROD type of encoder and yes, they do go wrong.
    If no second encoder, motor encoder is faulty.
    Apr 2022
    12
    Re: Need Help - Sinumerik 840D system
    hello, did you found the solution?
  1. Sinumerik 840C, Sinumerik 840D
    By marek-vavra in forum SIEMENS -> Sinumerik 840C
    Last Post: 09-02-2022, 07:04 PM
  2. Sinumerik 840D measurement
    By Docink in forum G-Code Programing
    Last Post: 03-06-2014, 06:50 PM
  3. help whit sinumerik 840d
    By hayabusa6606 in forum EMCO CNC Machines
    Last Post: 12-16-2013, 01:15 AM
  4. sinumerik 840d for mastercam x3
    By boll1986 in forum Post Processor Files
    Last Post: 11-01-2013, 10:24 PM
  5. Sinumerik 840D
    By M.RISHIKESH in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 05-24-2012, 03:14 PM
