586,675 active members*
3,217 visitors online*
    May 2005
    56
    mori seiki mill with a spindle problem
    i have a mori seiki mv 35/40 vertical mill and the spindle is doing goofy things, this machine ran fine until it was moved. we got it on the floor and installed a new encoder for the y axis on the back (a moron pushing a cart broke it), it homes out and comes up fine, but when you orient or try to give the spindle a command it jumps around as if it it fighting it self, it will turn on at the correct speed after a bit, but has no torque, i can grab the holder with my hand and make the load meter go over 120%, when you press the orient button it jerks back and forth, about half a revolution and the sensor is visible and if i grab the spindle and hold it on the sensor it will orient and the light will come on, but it will still try to move and the load meter still goes up and down. this is not a geared head it is dc, has a yasnac mx1 control/yaskawa electronics
    Apr 2004
    88
    As you have just relocated it, the very first thing that
    comes to mind is check the powers phase rotation.
    look at the coolant pump there is usually a correct
    rotation arrow on it.
    May 2005
    56
    the power is hooked up correctly, the motors all work and pumps turn correctly, we can dry run the machine, its just the spindle giving me a problem
    Mar 2004
    564
    Check all connectors/plugs on drives and amps,check fuses for single phasing.
    sometimes things come loose in the elect. cabinet when being moved......
    Also, not sure if this could happen but....if the new electrical drop you are using is slightly higher in voltage, maybe you need to tune your spindle drive (gains)???
    How long was it "un-plugged" for????? perhaps you have lost a piece of data or it has been corupted by the loss off power. I had a windows based system do that to me, when it was left powered down over night, we could'nt figure out why half our set up was gone.....
    menomana
  1. Need Operators Manual - Mori Seiki SL250
    By BenBosun in forum Mori Seiki Software
    Last Post: 09-11-2017, 10:13 AM
  2. New Mori Seiki site
    By Waynno in forum Uncategorised MetalWorking Machines
    Last Post: 12-20-2012, 03:28 PM
  3. Sweo spindle drive? new mill dead spindle
    By Shizzlemah in forum Fadal
    Last Post: 12-18-2008, 06:11 PM
  4. Mill spindle repair?
    By kong in forum Uncategorised MetalWorking Machines
    Last Post: 04-02-2005, 07:01 PM
  5. Gilman box spindle pics
    By Swede in forum Benchtop Machines
    Last Post: 03-30-2005, 04:41 PM
