586,406 active members*
2,858 visitors online*
    Oct 2010
    Which control software lets me create a custom UI
    Programs like Mach3 are too techie and too complex for my users. Is there CNC program that let me create a custom user interface?
    Mar 2004
    1806
    While it is somewhat dated, if you get TurboCnc (DAK Engineering - Home of TurboCNC) and register it, you will get the source code which is written in pascal. You are free to customize it anyway you want. It is a dos program so it is fairly light in resources and just business on the screen. Don't even "have" to have a mouse to run it.
    The owner Dave K, says he should have an update out soon.
    Art
    Oct 2010
    Pascal would be way beyonfd my capabilties. However, looking further it appears that perhaps Mach3 allows one to create macros using VB, is that correct?
    If so, could a custom front end be used to operate Mach 3 transparently?
    Thanks for your help.
    Mar 2004
    1806
    I am aware that you can do VB scripts and I have a friend that has tried to implement Mach in a different manner. However the last time we talked, he was mired in the depth of the project and hadn't gotten to far! As I don't use Mach, can't comment much further.
    As for pascal, I am NOT a programmer by any means, but I have been able to pick up enough of it to do what I want.
    Art
  1. Fanuc Focas Custom PC Software
    By fanuc-support.c in forum News Announcements
    Last Post: 06-14-2011, 10:39 PM
  2. How to create custom appearances
    By hindocarina in forum Solidworks
    Last Post: 07-07-2010, 03:24 PM
  3. control system for custom cnc machine
    By kpk250 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-30-2007, 10:12 PM
  4. 4 Axis EDM software , used to create foam cutting path?
    By bgriggs in forum CNC Wire Foam Cutter Machines
    Last Post: 09-29-2005, 10:52 AM
