I have had a few of muy customers ask me to de4sign and build for them a CNC wood lathe. At the time I was not very interested. Recently, I had two more requests so I am reconsidering designing and build an add on retrofit to one of the inexpensive wood lathes ($160).
The cnc retrorfit portion would be a bolt on except for the spindle.
Here are the features I have though about so far.
Length of machine from ebay 40"
Spindle would have both the stock motor and a stepper motor that can be attached via a timing belt for indexing and to rotate the stock.
The Z axis( long axis on a lathe) would be rack and pinion driven by stepper motor. The X axis ( cross slide) would be driven by a stepper and an acme leadscrew.
The C axis is a large stepper motor connected to the spindle for indexing or used as a constant turing device
The cross slide would primarily be set up to use a trim router for cutting but other tools could be mounted also.
Any other features that would be must have?
Comments
Dan Mauch
Camtronics, inc. -- CNC with Dan Mauch
[email protected]
