586,384 active members*
3,720 visitors online*
    Mar 2009
    Fanuc 11M Blank Screen
    we are a high school vocational Machine Trades class with an early 1980's Takasawa vertical CNC Milling machine with a Fanuc 11M controller.
    The mill has always been dependable, we even had all of the students use it already this school year. We had not used it though for about 3-4 weeks then went to start it up this past week and the screen did not come up at all?? I powered down the machine thinking it was a fluke, but still no screen.
    this is where we are at right now:
    1. I have removed and checked every fuse i can find with an ohm meter
    2. when we power down the machine, the screen flashes green for a split second.
    3. when the machine is powered up
    ** it does not let us move the table, home the machine or anything else.
    ** all fans, hydraulics, etc. seem to come up fine.
    ** 7-segment LED display on the "motherboard" has a "9" displayed.
    Like i said before, we are a High School, so as you can guess our budget is very tight. any help or suggestions of what to check next would be greatly appreciated.
    Thank you,
    J.D. - Instructor
    Oct 2010
    68
    Call Fanuc FA America. 888-FANUC-US. They have service engineers that will help you diagnose your problem at no cost. If you are competent enough to use a multimeter and possibly swap some boards, there should be no need to have a service engineer come out to look at your machine. If you have a bad part, keep in mind that you don't have to buy from Fanuc. There are companies like Tennessee Industrial Electronics that will sell you a refurbished part or repair yours at a lower cost than Fanuc would. You can also try ebay for parts as I've done ok finding stuff on there.
  1. Bridgeport EZ Trak SX blank screen
    By Panther101 in forum Want To Buy...Need help!
    Last Post: 06-04-2008, 09:47 PM
  2. Blank Screen
    By star-turn in forum European Club House
    Last Post: 07-29-2007, 06:54 PM
  3. CAPTAIN L470 blank screen
    By CIMMaster in forum Okuma
    Last Post: 07-11-2007, 08:09 PM
  4. Fanuc 3M Blank Screen
    By nastek in forum Fanuc
    Last Post: 10-31-2006, 02:56 PM
