586,390 active members*
3,152 visitors online*
Results 1 to 15 of 15
    Sep 2006
    94
    Mori Seiki Fanuc O-T Error EX357
    Hello again.
    I have a Mori Seiki SL-25B5 that gives me an error "EX357 Turret Index Time Up" whenever I try to index the turret.
    Any ideas?
    Heath
    Feb 2009
    6028
    If the turret pops out, and doesn't rotate, probably the unclamp switch. If it rotates then goes back but times out, it could be the clamp switch. You really need to check the I/O signals and see whats not right. If the machine sat for a long time, my guess is it's a clamp switch not popping out with the turret. A little WD40 works well. Those early machines do eat Bestac Boards, which is a small relay card. They are pretty cheap.
    Sep 2006
    94
    Well,
    the turret pops out. The error comes up as soon as you let go of the index button.
    The only switches I see on the turret are on the tail. One axial and several radial. They are are proximity switches.
    What are the addresses for the I/O's?
    Mar 2008
    31
    Check dgn21.2 for turret clamp fin. After turret pops out, dgn21.2 should turn to "0". If remains as "1", turret rotation is not possible. Proximity switch label as SQ14 or LS14 may be bad. Good Luck!
    Sep 2006
    94
    Quote Originally Posted by dbstream View Post
    dgn21.2 does indicate that LS14 is working correctly. (changes state)
    Mar 2008
    31
    Check dgn48.4 for turret index start output which turn on bestact relay KR15(inside electrical cabinet) & solenoid valve YV81(mounted above index oil motor). Either KR17 & YV91 or KR18 & YV90 should turn on for rotational output.
    Sep 2006
    94
    dbstream,
    On the bestact board, which ones are KR15, 17, and 18?
    I have no electrical prints.
    dgn48.4 does change.
    Mar 2008
    31
    KR15 is sixth "led" counting from the top. See attached
    Attached Files Attached Files
    Sep 2006
    94
    Been a while but I am back on the Mori. 48.4 and KR15 both change state. KR17 & KR18 do not turn on at all.
    Does anyone know anything about timers in the parameter list?
    Feb 2009
    6028
    You need to check the physical output of the KR15. The led on the board is just the control voltage to turn on the relay. It's the relays that fail themselves. All timer descriptions are in the back of the ladder diagram.
    Sep 2006
    94
    Well I got it.
    The timers where set to 00000000.
    Neet, huh?
    Thanks again for the help fellas! I appreciated it.
    Heath
    Jun 2014
    Re: Mori Seiki Fanuc O-T Error EX357
    Hello, a new member here. We just started to have a problem with one of our Mori Seiki that's been in use for over 9 years now. We did take it out of service for a short time when we got new replacement machines, but had to put it back in service when one of our Okuma machines went down. It was running fine for quite a while, but it is just now showing the message EX 0357 Turret Index Time out. The program starts ok, does the rough passes, but when it indexes the new tool for the final pass, the message appears. Our lead operator also found these alarm messages in the history:
    749 S-spindle LSI Error
    500 Overtravel +Z (2 times)
    400 Servo Alarm - X axis overload
    414 Servo Alarm - Z axis detected Error
    751 Spindle - 1 Alarm Detect (3 times)
    414 Servo Alarm - X axis detect
    750 Spindle Serial Link Error (3 times)
    501 Over Travel -X
    The serial link error may have been caused when I was checking the cables in the back. Any help would be greatly appreciated. Thank-you.
    Feb 2009
    6028
    With a 0t, I'm guessing well over ten years old. Kinda hard to help without knowing the model number.
    sent from me
    Jun 2014
    Thank you for your reply. I didn't get a chance to talk to our daytime tech to find out what they did, but they were able to get it working. I believe that there is a proximity switch inside that tells the machine when the turret is back in position, but I was unable to remove the cover last night. Anyways, to make a long story short, we just have to make this machine limp along for less than a month when we will be installing a brand new Mazak CNC machine, which is taking the place of our old Okuma machines. Once again, thanks.
    Feb 2009
    6028
    I'm sorry, never fun going backwards.
    sent from me
  1. Mori Seiki JR - ATC Error message?
    By shortlane in forum Mori Seiki Mills
    Last Post: 03-17-2013, 09:29 PM
  2. Mori Seiki MSC-501 - EX2060 Error
    By japi in forum Mori Seiki lathes
    Last Post: 11-13-2012, 12:14 PM
  3. MORI SEIKI MV-40B FANUC OC EX0625 ERROR CODE
    By cebjr79 in forum Mori Seiki Mills
    Last Post: 06-28-2012, 05:08 PM
  4. Mori Seiki Fanuc 3T error
    By haitd in forum Fanuc
    Last Post: 03-08-2012, 08:51 PM
  5. MORI SEIKI MV JUNIOR system error 912- FANUC O-MC
    By janez9 in forum Mori Seiki Mills
    Last Post: 05-16-2011, 01:53 PM
