586,761 active members*
7,452 visitors online*
Results 1 to 20 of 20
    Mar 2009
    i'm looking for lantek expert v 27
    hello there.
    its possible to tell me here i can find lantek expert v27. do you know any site to download it free.
    thank you in advance
    ps
    sorry if my question is illigal.
    Aug 2010
    Unfortunately no. I have not used Lantek in a very long time. but I will do a search for you and see what I can find.
    Jonathan
    Aug 2010
    Well, it is not free. this website shows it for $150.00.
    Here is the link:
    Lantek V27 - Mold - free-download|Unlimited|license|serial|unlock|keygen|fr ee|activation|patch
    Aug 2010
    It states that it is free...but that is a 30 day trial I believe. Then after that it is 150.
    I hope this helps.
    Jonathan
    Feb 2015
    8
    Re: i'm looking for lantek expert v 27
    Yes, i have it ISO File ... Uploading in Process .. then will share URL Link
    Feb 2015
    8
    Here's the Download Link :
    Lantek v.27
    https://drive.google.com/drive/folde...nM?usp=sharing
    Oct 2016
    Quote Originally Posted by o_secret_k View Post
    Lantek v.27
    Hello, ty for the link. Is the version of Lantek Expert cracked because it require cd-key ?
    Feb 2015
    8
    Quote Originally Posted by Lansvans View Post
    Check inside the ISO there is a Magnitude folder, there is a text file ... you will find the cd-key
    it's Mandatory to install LANTEK v27 on Win x32 bit Not x64 .. So the Emulator be able run
    any Questions iam ready to help
    Mar 2019
    Dear all,
    On Windows 32-bit, I have install it from ISO file and all goes well until the registration key, i put the key as decribed on txt file and i follow the steps correctly. when im trying to install the Emulator Utility on this step do nothing.
    Can you give me a little help on this step ?
    Thak you very much in advance !
    Mar 2019
    Hello guys i am trying to install this but i get problems with SQL Server and stuff. Also don't find the Emulator in any folder?? Could i also get help? I need to learn the program realy well. Thanks!
    Hello,
    should that be Windows XP 32? Because on Win7 32bit after running emulator utility as admin, it opens but after pressing install emulator nothing happen. Any thoughts?
    Thanks in advance. Best regrads,
    Mar 2019
    Did you find any solution about this issue ? cause i have not receive any answer by other guys.
    If you have any fix for this or you have any other version that is working please send me an email to my personal email.
    [email protected]
    Thanks in advance !
    Hello follow the steps in this tutorial to the letter https://drive.google.com/open?id=1WU...JWBacugXJKnlE2
    Jun 2019
    Quote Originally Posted by dimitristef View Post
    Dear all,
    That is because it is illegal to use a pirated version of Lantek and proper security measures are taken to be sure this does not happen. If you would like to operate Lantek contact your local sales office and pay for full functionalities.
    Jun 2019
    Dec 2017
    9
    I'll tryit
    Dec 2017
    9
    Quote Originally Posted by abdulbari View Post
    I'll tryit
    I have installed the program and move the file so system 32
    And i used the key still one thing using emulator
    It doesn't work
    How can I make it work..
    Mar 2021
    27
    Thank you for the link!
    Feb 2022
    Hello everyone, I have the Wibu key, but I am unable to get the PC to recognize it. I have tried several versions of the Lantek Expert and there is no way to use it, for that reason if someone can give me a lantek that I can use without using the key, which is what gives me problems, I would be very grateful, thank you very much everyone for your work.
    Ya Welcome Ya welcome, Update the Link Pls.
  1. lantek expert 1
    By boomer187um in forum CamSoft Products
    Last Post: 01-13-2024, 09:26 AM
  2. Lantek
    By scott24 in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 07-22-2020, 06:55 AM
  3. lantek expert use
    By agiorgos in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 05-30-2020, 08:56 AM
  4. Lantek Expert
    By one5 in forum Laser Control Software
    Last Post: 04-20-2013, 07:29 AM
