Hi everyone. My question is which method is better and why?
1. Material TI 5
2.using Iscar 1 inch dia insert drill drill aprox 2 inches deep.
This is where I question using the emill and spinning the chuck to rough the ID Bore verses a 5/8 inch shank boring bar.
Do it this way.
3. Use a 1/2 inch emill to rough out the id to within .005 per side of finish dia which I will say is 1.250 dia.
OR this way.
3. After Iscar drill and then rough bore the ID using a boring bar 5/8 shank or largest possible size boring bar. It requires several small passes inside on the bottom of the bore to do this.
We have to use the boring bar to finish the ID anyway.
Feedback is appreciated.
