586,544 active members*
2,516 visitors online*
Results 1 to 4 of 4
    Feb 2009
    5
    Round column build
    I have a ZAY7032G mill that I have owned for about 10 years and it is mostly used for drill press purposes as it is a geared head... I have a bridgeport clone mill for general milling
    I was wonder what the feasibility is of removing the round column and geared head which I would keep to use for a drill press (attach it to a steel frame) and construct a new direct drive head and column and CNC it all...
    Does this sound feasible... I know it would be a lot of work, but I need to keep the geared head for drill press duty but want a small CNC mill as well...
    Jun 2008
    614
    it depends...are you looking for cost effectiveness or you just need a new challenge?
    i do believe a square column machine of this size...ZX45? can be had for about $1700...that being said why not just keep your machine the way it is for heavy duty general work and get something like a G0704 or any of the BF20L machines to convert to CNC...the G0704 is a steal at about $950. remember the bigger the machine the more expensive it will be to cnc...
    http://www.g0704.blogspot.com/
    Feb 2009
    5
    Over here you can double those prices for what we pay even though our dollar is nearly parity with the US $..
    Jan 2008
    1533
    With the dollar as it is, importing looks pretty attractive at present.
  1. Round column mill?
    By bearwen in forum Benchtop Machines
    Last Post: 01-06-2010, 03:02 PM
  2. Round column mill
    By rodzilla in forum Benchtop Machines
    Last Post: 08-16-2007, 02:00 AM
  3. converting a round column
    By Paul in OK in forum Benchtop Machines
    Last Post: 10-27-2006, 10:15 PM
  4. Round column mill
    By SCROMAL in forum MetalWork Discussion
    Last Post: 06-18-2006, 06:23 PM
  5. HARBOR FREIGHT small round column mill to a square column conversion.
    By motomitch1 in forum Vertical Mill, Lathe Project Log
    Last Post: 12-01-2005, 05:24 PM
